Hong Kong E60 sub-Forum
Old 04-19-2010, 04:20 AM
  #22431
newbie2's Avatar
Originally Posted by ricky1329
"Day running light" can turn on and off in the iDrive menu under light-settings.
This thread may help
https://5series.net/forums/index.php...dpost&p=317192
If I remember correctly, the DRL should be off in my case. I have read through the menu and understand that this function should control the headlight to turn on even in daytime in auto mode.
However, I will double check the setting in idrive. If this is already off and still not working in auto mode, what next? Any good garage to recommend to fix it? Is the sensor on the windscreen has problem?
Old 04-19-2010, 04:22 AM
  #22432
newbie2's Avatar
Originally Posted by mark_hk
So basically, i should turn off DRL in i-drive and then the "auto" light function should work!?
Mark
Did you try turn off the DRL and test the auto mode again?
I am not going to drive in daytime these few days, so cannot test. Hope you can test and let me know the result.
Old 04-19-2010, 04:25 AM
  #22433
newbie2's Avatar
Originally Posted by keith84_uk
Have you guys tried to turn off the "day running light" function in i-drive?
Hi Keith, as I remember, I have turned off the DRL in my baby but I should double check it. Any other possible cause of the problem?
Old 04-19-2010, 07:30 AM
  #22434
ricky1329's Avatar
My Ride: 530i Mods: M5 sporty package, M5 Steering wheel, Sprint Booster
DRL turn on; Bad light sensor; need software upgrade.
Old 04-19-2010, 08:52 AM
  #22435
pinguhk's Avatar
My Ride: Mini Cooper
:thumbsdown:
Im connected 24/7 by my blackberry!
yeah that for work.
Old 04-19-2010, 08:59 AM
  #22436
pinguhk's Avatar
Originally Posted by kcleung
easy to use and great to look at and solidly built, what more can one ask for from a product take a look at the # of people on mtr holding an iphone
well I don't know about solid built
milton has change 3 phones in 1 year and my friend at work has change his 2 time.
Old 04-19-2010, 09:00 AM
  #22437
pinguhk's Avatar
Most Europe airports closed, France, Germany, Sweden, Holland, Belgium, Italy...etc
So bascially i have to stay here till it reopen!
just to let you know it getting worst.
There are more ash coming
Old 04-19-2010, 09:06 AM
  #22438
mark_hk's Avatar
Mark
Yeah mine is working now! i changed my settings in idrive, and now it turns on when its cloudy/dark and off in the day light!
Old 04-19-2010, 09:08 AM
  #22439
pinguhk's Avatar
Thanks for reply.
Mine baby is made in 2005 Dec and first register in 2006. When I bought it, it was just 38000KM. However, I have to change the suspension cushion on the front because there are some funny noise coming out. After changed the cushion, it becomes a very quiet horse now. In addition, I have changed the new tires, using BS RE001...good!
By the way, I have a friend who brought a brand new E60 in 2008 and he has the same problem with me in auto headlight. He has went to BMW service to fix it but the result is the same!!! Means no fix. Also, I see many BMW turned on headlight in daytime and I think they are facing the same problem.
Any more share?
for the day time lights just turn off the daytime light in the idrive.
you know that is funny all members 2nd hand car have the same km as you when they got there which mean it has been pushed back.
If the suspension cushion needed to be change then the car has done at lest 650k km.
my old 2004 had done 640k km from new and I dont drive it that much and did not need to change the suspension cushion.
I would check all the 6 wishbone for cracks.
it is 100% will need to change.
we all have change ours at about 500k km
Old 04-19-2010, 04:50 PM
  #22440
kcleung's Avatar
That's bcos he tries to make the most of the v good warranty program. Billhk replaced a lot of the parts in his e60 for the same reason. Anyway, u hold a iPhone in ur hand, u can immediately feel the case is v solid and has little flex.
Quick Reply: Hong Kong E60 sub-Forum
