Hong Kong E60 sub-Forum
Old 04-11-2010, 11:53 PM
  #22191
wnshie's Avatar
Originally Posted by kcleung
No need, nail on the side wall will do it. It's work smart not work hard.
Should be the "corner" of the tyre I was told more than half the time the leak can't be fixed if in this case...
Old 04-12-2010, 12:01 AM
  #22192
wnshie's Avatar
Originally Posted by mark_hk
Has AK got materials on hand, or he has to order? I would like to get mine done sometime soon....
Ricky - rear tyres still hit my fender! spacers are still affecting the car! running out of ideas... either have wheels cannot come out so much, or i have to raise suspension which means buying new shocks/springs!
Give it up la man, you just need thinner spacers man... Or, the more expensive option will do too... PSS10 with indoor electric height adjustment (I recall Dai Lo Bill mentioned it ), then you can leave it on high end during everyday drive and then you can lower the car when you feel like a nice low cruse over a flat smooth highway...
Old 04-12-2010, 12:02 AM
  #22193
wnshie's Avatar
Originally Posted by pinguhk
he is called ???
Since when you can type Chinese now
Old 04-12-2010, 12:07 AM
  #22194
wnshie's Avatar
even he get the right offset they will rub.
have you seen the car soooooo low man
yeah man, it's your car, it ain't you man... you might want some at LKF from some L, not the tyres on you car man...
Old 04-12-2010, 12:16 AM
  #22195
pinguhk's Avatar
My Ride: Mini Cooper
never my friend got it for me.
Old 04-12-2010, 12:17 AM
  #22196
pinguhk's Avatar
Old 04-12-2010, 12:22 AM
  #22197
pinguhk's Avatar
is AK OK now?
here is some thing for AK and you guys that love M3
http://www.youtube.com/watch?gl=US&f...&v=YlMZ_v7rJs8
Old 04-12-2010, 12:31 AM
  #22198
mark_hk's Avatar
get the FSD, the car is way too low.
The car is not way too low... i like the low stance. Looks aggressive! Its just trying to get the right balance between the low height and how much the wheel comes out!
Old 04-12-2010, 12:32 AM
  #22199
mark_hk's Avatar
Originally Posted by Small Tomato
Get a set of wheels with right offset ... and remove the spacers ...
Doesnt matter about offset. Even if i had the "right" offset, the wheels would still be flushed with wheel arches, but because my car sits low, it WILL rub the fender/wheel arch.
Old 04-12-2010, 12:35 AM
  #22200
mark_hk's Avatar
Thinner spaces would mean vibration and the wheels will not be flushed with the wheel arches.
I have already started looking at coilover alternatives! The bilstein pss10 with electronic ride height is a bit on the pricey side!
Quick Reply: Hong Kong E60 sub-Forum
