Hong Kong E60 sub-Forum
Old 07-28-2009, 04:32 AM
  #13731
billhk's Avatar
My Ride: carbonized MB coupe
KC you're right
my car was diagnosed with:
cracked thrust rod (supports the shocks and springs)
Faulty electronic water pump
all replaced today
Originally Posted by kcleung' post='956549' date='Jul 28 2009, 06:39 PM
strictly speaking, It's the springs that absorb vibration, the shocks are dampers.
From how u described it and how it braked last time I drove it, I would do it sooner rather than later and I would buy set of springs and shocks rather than mix and match
Old 07-28-2009, 04:46 AM
  #13732
billhk's Avatar
i just had the same feeling, and the thrust rod was cracked, get AK to get it done asap, jack it up and take apart the shocks and springs and use strong lamp.
Koni could be the best if it is more comfy!
Originally Posted by keith84_uk' post='956240' date='Jul 28 2009, 12:10 PM
ET, my shocks are in pretty nasty situations in these few weeks.
Now actually the chassis absorbing the shocks from the road but not the suspension.
So i am saving money now for the new shocks and thinking which to get. (Looking for cheap option)
So how much is your KONI cost?
When i test drove your car last time, the Koni wasnt the sportiest suspensions around but it definitely absorbs the road noises and the vibration.
Which is what i want
Old 07-28-2009, 06:54 AM
  #13733
keith84_uk's Avatar
My Ride: BMW E60 530i , Silver with leather Air Con iDrive 17" Breyton Rims with Dunlop Sp Sport tyres (M-Tech Bodykit and rims WANTED) Alfa Romeo 147 TS1.6 , Black with Air Con 17" Multi Spoke alloys with Bridgestone RE040 tyres Toyota MR-S 1.8 VVTI , Lagoon Blue with Red leather Air Con 15" standard alloys with Toyo tyres Toyota Celica 1.8 VVTI, Lagoon Blue, Air Con, 16" Standard alloys with Kuhmo KU31, EBC Green Stuff
So do you rekon i should change the springs at the same time?
But my Eibach springs are pretty new i think (About 2yrs)
Old 07-28-2009, 06:55 AM
  #13734
keith84_uk's Avatar
We had the same problem bro
And yes, got to agree with you guys, will need to change it asap
Old 07-28-2009, 07:24 AM
  #13735
etchu's Avatar
I think KC means buy a set of shock/spring combo instead of buying them separately to make sure they can work well with each other. koni sells a package of it's fsd shocks with eibach spring (which is the same as the black one we are using), so you can get koni and be sure that they can work fine together as a set.
Old 07-28-2009, 08:58 AM
  #13736
kcleung's Avatar
yep, sounds like these koni shocks is what Keith needs
Old 07-28-2009, 06:39 PM
  #13737
keith84_uk's Avatar
Got to save some money now and will do iy as soon as i can, thanks gents
Old 07-28-2009, 07:27 PM
  #13738
kcleung's Avatar
I am sure lots of credit card telesales will love to lend you money.
you are not worried that the vibration will shake your cars into pieces and cause more repair later on?
Old 07-28-2009, 07:52 PM
  #13739
etchu's Avatar
that's right, Keith get it ASAP man.
using the frame to absorb vibration is a bad bad thing to do to your car.
Old 07-28-2009, 07:53 PM
  #13740
etchu's Avatar
yea the koni FSD is not bad, sport and comfy. It's the stock shocks for Gallardo too.
Quick Reply: Hong Kong E60 sub-Forum
