highway vibration
Old Mar 14, 2011 | 08:01 AM
pauliehcfr's Avatar
2004 545 manual transmission. at around 70 mph, I get a vibration from the rear of the vehicle. not violent , but kind of like a butt massage. shifter and passenger seat shake a little. I've been through rims,hub rings, tires, balancing, etc. everything looks good and tight as far as suspension, but the vibration is still there. anyone have this and get it corrected? I'm thinking of a lot of different things as to what it can be but don't want to just go and replace part after part. thanks
Old Mar 14, 2011 | 09:35 AM
or_550i's Avatar
Check the prop/drive shaft. Maybe a weight came off. Otherwise you might want to try a different tire shop.
Old Mar 14, 2011 | 10:28 AM
andrewsweetnam's Avatar
My Ride: 2009 535D M Sport Carbon Black, 172s, Boot spoiler, Tinted Glass, Media pack, Visabilty Pack, Hifi Upgrade, Electric memory heated Seats, Heated steering Wheel, Sport auto Trans,
A worn rear shock could be to blame it could be the rear wheel bouncing up and down that you can feel.
Old Mar 14, 2011 | 10:47 AM
Cwest's Avatar
More info may help.. What kind of rims? OEM or replica or aftermarket..? What balancing machine was used to balance..Etc
Old Mar 14, 2011 | 11:37 AM
pauliehcfr's Avatar
Thanks for the replies folks. They are 18" TSW wheels in a staggered set up. The old wheels had cracks and bends and were the result (I think) of the vibration originally. New rims and tires and vibration was better. Vibration came back a few months later and one of the rears had a bubble. Replaced tire and all was well until recently. I was thinking that one of the rear shocks might be worn causing the wheel to hop. I actually replaced the driveshaft a year ago and it didn't help. The hub rings are plastic and correctly sized.
Old Mar 14, 2011 | 11:46 AM
525iEnjoy's Avatar
Check the play on the rear wishbone or dog bone mount? Older cars had these issues. Have you ever swapped your rims back to stock and did the same issue occur?
Old Mar 14, 2011 | 11:57 AM
pauliehcfr's Avatar
Think I found it. Let me know what you folks think. Crawled under and checked the rear bushing that supports the differential. It rubber has separated from the metal and has som play in it.
Old Mar 14, 2011 | 01:40 PM
525iEnjoy's Avatar
check those upper arms too
Its either #14 guiding, 19 wishbones or 2 balljoint
Old Mar 14, 2011 | 02:50 PM
pauliehcfr's Avatar
I also noticed that the rubber boots on the wishbones are torn, they're tight, but leaking grease.
fabolous531
Oct 18, 2015 12:22 PM
EuropeanArtz
Sep 23, 2015 08:21 PM
ripley
DIY: Do It Yourself
Sep 19, 2015 06:21 PM
hmilycar
Jul 31, 2015 10:07 AM
jfife83
Jul 25, 2015 04:14 PM
