High Speed Run RS6 vs 545 vs Sportbike
Originally Posted by wiszmaster' date='Jun 19 2005, 09:45 PM
**cough** RS6 = twin turbo V8 = 450HP? Vs.? 545 = NA V8 = 325HP **cough**
he either had some aditional lead taking up weight, or he must have NOT been on it allll the way, because the RS6 will move! these two cars are NO comparison whatsoever.
545 Vs. (B6/B7) S4 would be more like it, since the new V8 puts out about 340HP
[snapback]141054[/snapback]
Curb weight RS6 4060 lbs, with 4 big guys, 4860 lbs. Curb weight of my car (1/4 tank, lightweight wheels and tires), 3700lbs + me = 3860 lbs.
Now take drivetrain losses in an automatic of 20%, manual 15%. This gives Audi RS6 360 whp, BMW 545 276 whp. Calculate the lbs per hp for both cars.
Audi RS6 - 4860 / 360 = 13.5 lbs hp
BMW 545 - 3860 lbs / 275 = 14.0 lbs / hp
Close enough isn't it? Especially if he didn't get a kickdown from the slushbox.
You ought to get that cough checked out.
My Ride: '06 530i -6speed - Comfort Seats - Premium Package - Premium Sound Package - Cold Weather Package - Ventilated Seats - Xenon -HUD - PDC - Nav
Originally Posted by heezy545i' date='Jun 20 2005, 02:01 AM
Sounds like fun.? Hitting redline in 4th comes as a bit of a surprise, huh?
Is the RS6 a manual?? Perhaps he didn't downshift.
[snapback]141080[/snapback]
Originally Posted by colejl' date='Jun 20 2005, 07:35 AM
Those turbo's take a while to spin up...? ![Thumbsup](https://5series.net/forums/images/smilies/imported/thumbsup.gif)
[snapback]141119[/snapback]
but when in motion already ... unless you are running in the low 1K RPMS, or out top of the spool range, you will move - QUICK!
if you have ever driven one, you'd understand. but the new RS4 will most likely beat it with its V8 FSI 4.2l & 420HP, as well as its new all wheel drive system that is 60R/40F
Originally Posted by wolverine' date='Jun 20 2005, 11:56 AM
Curb weight RS6 4060 lbs, with 4 big guys, 4860 lbs.? Curb weight of my car (1/4 tank, lightweight wheels and tires), 3700lbs + me = 3860 lbs.
Now take drivetrain losses in an automatic of 20%, manual 15%.? This gives Audi RS6 360 whp, BMW 545 276 whp.? Calculate the lbs per hp for both cars.?
Audi RS6 - 4860 / 360 = 13.5 lbs? hp
Close enough isn't it?? Especially if he didn't get a kickdown from the slushbox.
[snapback]141169[/snapback]
damn cough .... I should go & see a doctor about it. ;-)
My Ride: E60 530d Sport - Carbon Black, Black Dakota Leather, Media Pack (satnav, bluetooth, CD changer), heated font seats, through load
Maybe it was just a S6, and not a RS6? ie no turbo.
Originally Posted by heezy545i' date='Jun 20 2005, 04:27 PM
Doesn't weight play less of an issue when you're already at speed.
Because a RS6 can pull away from an e39 M5 let alone a 545i
[snapback]141339[/snapback]
'yup, the e39 m5 is faster than the rs6 from 0-130, and in highway rolls. the audi will have it off the line, but the bimmer will slowly pass it above 100.
[snapback]141343[/snapback]
Also, weight is less of a factor at speed. I don't know what the RS6 drag is compared to the 545. Also, he was in front, so I may have benefitted slightly from a draft.
Originally Posted by wolverine' date='Jun 20 2005, 04:49 PM
The boys on the Bimmerfest board say otherwise.?
[snapback]141370[/snapback]
0-60 / 0-100 / 0-150 / 1/4 mile
RS6: 4.4 / 10.7 / 30.9 / 12.8 @ 108
M5: 4.9 / 11.5 / 29.2 / 13.4 @ 108
So yeah, I guess the M5 would take the RS6 over 100
well.... I don't think your wheels cut 100+ pounds off your car... the weight of the 545i listed at 3,814 pounds....
either way, he did have a lot more weight in the car..... you can roughly estimate 1 car legnth per person.....
I think the real issue that isn't being mentioned is that the RS6 is AWD, and while that is great for getting a jump off the line, it really kills the car when at speed... the AWD causes much larger drivetrain losses.... you'll always see better 1/4 mile times, and lower trap speeds with AWD cars....
Let's do some elementary calculations, and make a few favorable assumptions.
Originally Posted by wolverine' date='Jun 20 2005, 10:56 AM
[quote name='wiszmaster' date='Jun 19 2005, 09:45 PM']**cough** RS6 = twin turbo V8 = 450HP?? Vs.?? 545 = NA V8 = 325HP **cough**
[/quote]
Wolverine,
Sorry about that F1 experience. I watched the whole thing on TV and it was awful. I can't believe it ended like this. A really bad move for F1 in the US.
On the positive side. I am a huge fan of Schumi, and that way he got 10 points in the championship that otherwise he probably would not have gotten.
