High Pitch Whistling Noise at Cold Start
Old 07-01-2012, 10:49 AM
  #21
RTR
RTR's Avatar
Originally Posted by skunky
Check ur idle pulleys and all ur pulleys that ur belts ride on one of them probably has bad bearing
Car still whistles with serpentine belt off (however didn't take the AC belt off). But the fact that dipstick out / open oil cap stops the noise leads me to believe that it's not belt-related... Or can it still be AC belt?
Are your y pipes in good condition. I had the same noice on my car....unfortunately i got rid of the car before replacing it but thats what i assumed it was. It wont hurt to look into what a previous member posted earlier .
Do you mean the y-pipe for the air pump?
Thanks for the input guys!
Old 07-02-2012, 07:27 AM
  #22
skunky's Avatar
Use to have e46 that did that and it was one of the pulleys. Change idle pulley and .......cant remember which other one. Went away. My e60 starting to do that now. Guess its time to change this one too
Old 09-25-2012, 08:42 PM
  #23
RTR
RTR's Avatar
skunky
Not the pulley/tensioner. However I still have to remove AC belt and check the compressor.
Quick update:
Sometimes the noise stops exactly when the air pump shuts off. That exact second. Don't think it can be a coincidence. But it only stops with the air pump like 20% of the time. All the other times it continues for another ~15-20 seconds. Maybe the valve is sticking...
Old 03-10-2013, 11:26 AM
  #24
kalil147's Avatar
Hi
Did you ever fix the noise?
I am having this issue and its frustrating! My car whistles, and I get the check engine light with code P0507.
I checked the crankcase valves and they are both very clean and intact. No tears. Dont know if I should replace anyways. I feel if they have no tears replacing would be throwing time and money away.
Did you solve this problem?
Old 03-19-2013, 09:22 PM
  #25
RTR
RTR's Avatar
I don't think you have the same problem. The noise I have is weather-dependent.
Start with your code first and fix it. Maybe you have a vacuum leak, which would explain the noise and the code.
Old 03-20-2013, 06:16 AM
  #26
DavidF's Avatar
My Ride: 545i sport
To ensure air pump is not the culprit, simply disconnect the power source from the pump before a cold start. If the noise is gone, it is the pump or the related plumbing.
Old 03-20-2013, 09:02 AM
  #27
RTR
RTR's Avatar
Thanks. I've pulled out the fuse for the AP and the noise was still there. Also turned on AP with DIS when the engine was off, no noise.
It's not directly related the the air pump, but maybe a secondary air valve is sticking and it creates it...
Old 05-20-2014, 07:16 AM
  #28
seahawk's Avatar
Hi RTR,
Did you ever figure out what was the cause for the Whistling Noise at Cold Start? Got the same exact symptoms like yours on a 2006 550i
Thanks,
seahawk
gergnang
02-02-2021 07:29 AM
chadillac2000
42
09-13-2017 11:15 AM
YannickVT
05-07-2015 11:45 PM
navisingh
04-18-2015 02:20 PM
08-12-2003 11:41 AM
Quick Reply: High Pitch Whistling Noise at Cold Start
