High Mileage Refresh
Looking for the forum's collective wisdom.
What are all the things that should be done with a nice 100,000 mile 535i to refresh and set it up for its next 100,000 miles?
My Ride: BMW
First things coming to mind are:
All Fluids replaced
Suspension Bushing
Dampers
The above is only true if they have not been redone at a previous time. But when I removed my dampers on the car, I could easily compress them with little effort.
Bushings, tie rods & suspenion links all age and replacing them gives you the feel of a new car again
All Fluids replaced
Suspension Bushing
Dampers
My Ride: 2008 535i
I have an 08 535i with 91,000 miles and in the past four months I've had to replace the following due to failure
And I've done these preventatively:
Next up is new tire rods. Luckily, my buddy is a tech at my local BMW dealer, but even still, gotta pay out the ass to keep these cars healthy, but god is it worth it. The n54 on meth just PULLS
- new clutch
- new dual mass flyhweel
- new valve cover gasket
- new AC compressor (mine siezed and blew up)
- new drive/serpentine belt
- new serpentine belt tensioner + pulleys
- new upper radiator hose and associated gaskets
- coolant flush
- new air filters
- new oil filter housing gasket
- new oil filter cooler housing gasket
- new turbo vacuum hose lines (fraying from the heat)
- new spark plugs
- new air filters
- new brake pads
- new brake rotors
- brake fluid flush
- alignment
My Ride: 08 535xi Prem, Sport, Cold, Monaco blue/Natural Brown
Fluids, filters and plugs. Intake blasting and water pump wouldn't be a bad idea...
My car has 208K now and has original coils, and all suspension except the control arm bushings.
My Ride: 535i black on black
I have 140k on my 08 535i
I love the way the car drives but the maintenance issues are outrageous. I had a shop quote me 3k to repair the leaks and resulting damage. I will be getting rid of mine as soon as get all the oil leaks in order and would recommend you do the same.
Sal-cheeto (04-26-2024)
When the suspension parts are replaced, does that include the bushings? I have around 165k miles so what would be the recommendation?
Bushings
Suspension links
Tie rods
Shocks (done)
Bushings
Suspension links
Tie rods
Shocks (done)
These cars are very well engineered, and reliable, but they do have needs. High-mileage, turbo, german cars are going to need some love. Oil Filter housing gasket, and oil cooler gasket (if applicable) are common failures, and may be good preventative maintenance items. Trans fluid flush, Intake removed and walnut shell blasted to de-carbon (good opportunity for oil filter housing gasket, as intake will be off.) Maybe even starter motor if your at 150k+. Coolant flush would be a good idea. Power steering fluid and brake fluid flush are both easy and important.
If you're having any hesitation/stuttering, or rough idle, maybe look at the vanos solenoids. Maybe a bottle of techron by Chevron. Beyond all these powertrain parts, the suspension and brakes would certainly benefit from refreshing. Sway bar end-links are pretty stout, but check sway bar bushings, tie rods, etc. Lift car up and try to move wheels in every direction, play will indicate wear.
ProStreetDriver
03-06-2016 08:48 AM
