High engine temp via OBD
i have a high temperature in my car as well, i don't get the overheating message but when i see the temp via hidden OBD it going between 90 deg to 105 deg but when i open the heater with the highest temp, the engine temp go down to 77 deg, so i don't know if the problem is from the temperature sensor or from the thermostat or from something else??? the fan also is not working when the temp go high.
My Ride: 2008 550i M-Sport
I have a 550i and noticed this week that the temperature stays between 99 and 102 C. I do not get any messages. is this the normal range for this car?
My Ride: 2006 520d - 19" 172s- Remapped - LCI taillights V6 cables - LCI xenon headlights - Denison 500 with BTA1500 - led interior lights - OEM led number plate lights
Planned mods:
Folding mirrors - Modmynav kit - High gloss shadowline trim -
Diesels should run at 90 and petrols run hotter
UltimatePeter
DIY: Do It Yourself
05-12-2015 08:00 AM
