Help wiring aftermarket amp to logic7 system
My Ride: 2004 545i
Hello,
I took pics to help everyone know what I am talking about here, sorry if its already been discussed before (maybe we can make this a one stop shop for adding an aftermarket amp to a logic7 system.
Ok been researching all day, I didnt even know what my system was called before today or where the stock subwoofers were located (under the seat, cool!). Heres where I need help
Attachment 1 - How do I remove the wiring harness?![Help wiring aftermarket amp to logic7 system-imag0026.jpg](https://5series.net/forums/attachments/e60-discussion-2/135745d1482364963t-help-wiring-aftermarket-amp-logic7-system-imag0026.jpg)
Attachment 2 - What are these plugs and what are they for? they almost look like RCA Plugs but I think we have Fiber Optics not RCA![Help wiring aftermarket amp to logic7 system-imag0029.jpg](https://5series.net/forums/attachments/e60-discussion-2/135747d1482364963t-help-wiring-aftermarket-amp-logic7-system-imag0029.jpg)
Attachment 3 - Can someone tell me what color wires to splice into for the speaker wires that go to the sub so i can run to my amps high level inputs (or a low level converter)![Help wiring aftermarket amp to logic7 system-imag0027.jpg](https://5series.net/forums/attachments/e60-discussion-2/135746d1482364963t-help-wiring-aftermarket-amp-logic7-system-imag0027.jpg)
Attachment 4 - Whats this for?![Tongue](https://5series.net/forums/images/smilies/imported/tongue.gif)
![Help wiring aftermarket amp to logic7 system-imag0030.jpg](https://5series.net/forums/attachments/e60-discussion-2/135748d1482364963t-help-wiring-aftermarket-amp-logic7-system-imag0030.jpg)
Attachment #2 : Its fiber optic connector. You need to handle it carefully. I recently installed OEM Ipod Adapter ..It had same fiber optic cable with black sheath to protect.
My Ride: 07 550i Sports Package
You remove the wiring harness by pressing the tabs and sliding the harness to your right(not up). Attachment two is the fiber optic which is a part of the MOSt Bus if the ring is not complete non of your communication/entertainment will work. The most ring includes the CD changer, Idrive/Mask, Satellite, TCU (bluetooth, and amplifier. I do nt know where to splice the wires. Try doing a search I have seen someone posting about that.
Awest91
09-17-2022 11:05 PM
incoherent
04-15-2015 04:48 PM
