HELP!! (warning light) right front parking light malfunction
Old Sep 1, 2011 | 01:37 AM
Darkcityavenger's Avatar
My Ride: 07 335i sport, 01 530i and 02 325i
Hi all I took my 06 525I to the stealership today to have a warning light checked. I'm getting a yellow light that says (Right front parking light malfunction). I can turn lights on and all is working and the warning light goes out. The stealership ran same on their computer and after 130.00 told me nothing was showing up in the codes. They said it may be the right side halo light going bad but not sure. I had to remove the security alarm fuse because the alarm would start going off for no reason. When I would get in the car and start it the warning light would come on . Does anyone have any idea what would cause this. Thanks Dennis
Old Sep 1, 2011 | 03:40 AM
sanjsanj's Avatar
My Ride: E60 530d
Try this.
Sit in car, rotate light switch to fully to the right.
Then put key in ignition and start engine.
Then switch lights off.
Any difference?
Sanj
Old Feb 24, 2022 | 10:18 AM
grkoala's Avatar
My Ride: BMW 2003 530i comfort
Hi Sanj, the car was serviced two weeks ago.
Is what you’re saying about turning the light switch on and then cranking the car did not make a difference.
Im still get the intermittent “transmission “ warning dash signal which puts the car into limp mode or doesn’t start at all
TeRC_19kilo
Apr 18, 2014 05:48 PM
TheRacerBoss
22
Dec 12, 2010 11:19 AM
Vhutchris
Jul 1, 2010 01:53 AM
srx2870
Jun 30, 2009 05:56 PM
JetBlack
The Competition
19
Jul 14, 2007 12:21 AM
