HELP sport shifter not working!!!!
Old 10-30-2012, 09:44 AM
burntsushi's Avatar
My Ride: 2007 e60 530i
Exclamation HELP sport shifter not working!!!!
I've searched a few threads even PM'ed some members and still no solution. When car is in D(drive) the light next to the D is not illuminated, however everything seems to be working normally. When I move the shifter to the sport shift side same effect car remains in (drive) no illumination on the sport shift side. This is extremely frustrating!!
2007 530i
Old 10-30-2012, 09:49 AM
balbs's Avatar
My Ride: BMW
Does the sport shift still work, just not the lights?
Old 10-30-2012, 11:29 AM
pcy
pcy's Avatar
when you move the shifter to left (sport shift), do you see "DS" on the instrument cluster?
Old 10-30-2012, 02:58 PM
AchtungE60's Avatar
My Ride: E60 530i
sounds like you have an unseated ribbon underneath the plastic piece.
Old 10-30-2012, 05:02 PM
burntsushi's Avatar
Exclamation
On dash displays "D" even when shifter is moved to "DS"
When shifter is moved over it remains in "D" mode only.
Can you explain or do you have information on an "unseated ribbon?"
Old 10-30-2012, 06:16 PM
balbs's Avatar
My Ride: BMW
Regardless of any lights or cluster displays, does the sport shift still work?
Old 10-30-2012, 07:56 PM
burntsushi's Avatar
The sport shift is not working at all.
Old 10-31-2012, 07:07 AM
jaycal3's Avatar
My Ride: 04' 545i, Sport Package, Black, Active Xenon, ARS, Aux Input '10 Tahoe, Black on Black, leather, Nav/XM, 20" tires, full body kit, power 2nd row, loaded '93 Jeep Wrangler, lifted 4.5", 33" meats, Rampage Recovery Bumper w/Tire Swing, etc 25' Aquasport Osprey, Center Console,2012 200 HO Etec
Take the trim off and see if the "ribbon" is plugged in under the stick shift...
Old 10-31-2012, 10:16 AM
burntsushi's Avatar
OK I'll check it out. If the ribbon was unplugged would that affect the other gears too? makes sense but wouldn't the other lights not illuminate as well as the m/s?
*the lights for the other gears illuminate (D, R, N, etc.)
I'm going to do check that out hopefully thats it.
Old 10-31-2012, 10:59 AM
AchtungE60's Avatar
My Ride: E60 530i
There are two ribbons. One for illumination and one for shifting to SD an M. it will just stay in D if the specific ribbon is undone. This is a 30 second check and easy fix.
Quick Reply: HELP sport shifter not working!!!!
