help please! need advice check engine light auto gear box fail
Old Apr 10, 2016 | 09:50 PM
thang408's Avatar
My Ride: 2008 bmw 535i
Default help please! need advice check engine light auto gear box fail
Hello thank you for taking the time to read my post i really need your guys help i drive a 2008 bmw 535i the other day i was driving to work no problems turned off the car turned it back on and then the abs,check engine light, and the steering wheel light went on the read brake light has been on for a while did not know how to reset the light after i changed the brakes few months back but the car went into limp mode would not let medrive few feet before stopping lcd screen shut off electricty for windows wouldnt work unless the car was half on got it towed reset the lights but the car revs on its own i changed the battery with lnterstate battery DID NOT know i had to get it reprogrammed could this be the issue? i also have not changed the transmission fluid and i am at 125k brake pads are low too i believe
there is some lag while downshifting but i thought it had been turbo lag been driving in sport mode lately and after i changed my tires everytime i turned off dynamic ttraction control it said dsc limited
also most of electrical issues have been popping up over the few months my daytime running lamps my reverse lights lcd restarts sometimes
Attached Thumbnails help please! need advice check engine light auto gear box fail-20160407_183542.jpg
Old Apr 11, 2016 | 05:40 AM
BostonJon's Avatar
My Ride: BMW 530xiT (E61)
sounds like battery issues.
Old Apr 13, 2016 | 09:13 PM
Criper2000's Avatar
My Ride: e60 535...
Sounds like possible DSC module failure for your current lights. Can you read faults?
Old Apr 14, 2016 | 03:20 PM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
Could be DSC or it could be the alternator. I would check the alternator first it very well could be the voltage regulator going out on the alternator
e60gg
Sep 3, 2015 05:26 PM
Johnnywadd
Sep 3, 2015 01:23 PM
Mikeee
Aug 27, 2015 07:19 PM
ifarted
Aug 23, 2015 10:16 PM
segovia
Aug 29, 2003 10:17 AM
