Hi my lights were changes by me to LED bulbs and now the screen inside says number plate light failure, its got no voltage coming to them? any help would be appreciated, cant find a fuse???
thanks in advance |
These sound like they are not error free. Where did get them from? Since LED use up less power then halogen your OBC will identify this as a "bulb out" error. Do they work though?
If the above does not help, check the wires that lead into the trunklid via the right hinge near the battery. It can fray and short out. I posted here w/ pics when i had a trunk license plate lighting odie. Search for it.
You better turn off the number plate lights error check.
how do you turn this off?
thanks |
Originally Posted by iamnatio
(Post 1419278)
Have u tried turning off and on again after replacing them?
Eventually pull out the ignition key, then back on and start the engine again. You may deactivate the error checking with a DCAN or K+DCAN cable and modifying the LMA.TRC file. Ia have at home the parameters to be modified, if u do own the cable. |
yes i have tried this nothing is happening? my boot only opens with a key but that doesnt affect it they used to work okay now suddenly gone. if i give them my own supply from the read side light will that make me get more errors???
Don't do that !
Check the fuses in glove box. U must have missed one... |
okay will do that after work today. it defo wont be in the fuse box in the boot???
