Help needed
My Ride: Bmw e60 530se
Hi there
I followed a DIY on the msport retrofit steering wheel onto a 2003 pre lci car. It was a great help and I have almost finished mine, one small problem though, on moving across the MLF box or airbag ECU, I fitted mine into the bottom spoke location how ever the wires accidentally popped out of the box. My problem Is I need to push them back into the white connector but in which order? There are 12 holes but only six wires, I'm hopping that some one might have a diagram or picture to help.
Any help would be great
Thanks
Rob.
Thanks
Rob.
Your right I should have added a pic in the original post, here you go:
This is the white block that the 6 wires popped out of, there are 12 spaces inside the block connector
![](http://i1315.photobucket.com/albums/t590/robert_patterson2/null_zps82672e4c.jpg)
Another shot of the block
![](http://i1315.photobucket.com/albums/t590/robert_patterson2/null_zps145bfdfb.jpg)
And the MLF airbag control module
![](http://i1315.photobucket.com/albums/t590/robert_patterson2/null_zpsd3221eee.jpg)
f any one has an SE steering wheel and they wouldn't mind popping it open to take a pic of the wiring gong in to the MLF control module or if some one has a wiring diagram then I would really appreciate it if they could send me the details, They would be a real life saver
^^^ Thanks for the diagram ^^^^
Unfortunately neither the connector or part is numbered so its quite difficult to follow the diagram, if any one has a colour picture of the part then it would be a great help.
Thanks again
Thanks again
stillak
04-22-2015 04:30 PM
