help me adjust my headlight range
Old Oct 21, 2009 | 01:36 AM
higher's Avatar
My headlights (low beam) are set way too low, particularly the off-side. Causing me to wander around the lane between the white markers.
There are two while hexagonal plastic adjusters bolts either side of the headlight unit when looking down on the light with the hood up, which one adjusts the up /down range of the headlight ? The left or right bolt (looking from front of car). I guess one must do left / right and one up /down ?
Anyone successfully done this and have any tips before I try and adjust the off-side range up a little bit.
I have the range set full up on the internal adjuster wheel and changed the bulbs to Phillip Xtreame.
The car is an 2008 E61, do they set them low anticipating extra loading.
Thanks for any guidance.
Old Oct 21, 2009 | 05:30 AM
stoic1's Avatar
My Ride: '04 545i, sport pkg, premium sound, sprint booster,
Check this thread, https://5series.net/forums/index.php?showto...mp;#entry237331
There is a DIY thread posted not too long ago, though I can't seem to find it.
Old Oct 21, 2009 | 08:18 AM
or_550i's Avatar
Yep. That's it.
I didn't realize there was an internal adjuster - is that a European model difference? Maybe the auto-levers are busted.
Old Oct 21, 2009 | 09:01 AM
Allen's Avatar
My Ride: 535i 6-speed
I took this from one of those threads I think
There is a headlight level sensor attached to the right front suspension. Each headlight unit has two adjustment devices, they are white with a hex-head (and inside that a phillips screw head) opening. The inboard (closest to the radiator) ones adjust vertical aim. Turn them clockwise to lower the headlight aim, counter-clockwise to raise it. Note: Lateral (horizontal) adjustments are usually not necessary.
Adjust vertical adjustment screw on each side.
Clockwise = light beam down
Counter Clockwise = light beam up
Start with 1/4 or 1/2 turn, and fine-tune from there.
Old Oct 23, 2009 | 05:28 AM
higher's Avatar
Thanks for the replies - appreciate the guidance.
Kaane
Mar 15, 2022 05:16 AM
vince_e60
May 26, 2018 10:02 PM
umnitza
Nov 3, 2015 02:58 PM
Sep 13, 2015 05:49 PM
umnitza
Sep 2, 2015 11:28 AM
