HELP: Hesitation problem...
I have a 2005 BMW 545i, it currently has just about 95K miles. I am experiencing a hesitation/ misfire (throws a quick service light, then it disappears) at low RPMs... say around 1500 rpm. I just performed an online change, a buddy of mine suggested replacing the spark plugs will do the job... however, before I dump money in hopes to finding a solution, I wanted BMW enthusiasts to input their opinion. Please feel free to speak your mind. thanks!
My Ride: BMW E60 M5
Model Year: 2010
Engine: S85
If you didn't change the spark plugs at 50k I would go head and do it now. I changed my spark plugs in my car at 57k and at 98k that's me being anal about maintenance though. What's a online change? Did you mean oil change? Did you check for any loose wires anything out of the ordinary under your hood?
Sn3akerh3ad most likely changing the spark plug is your best route cuz the exact same thing happened to me. (freaked the hell out of me when it happened).
My Ride: BMW E60 M5
Model Year: 2010
Engine: S85
. Each person takes care of their car differently then others. For example I usually do oil changes at 7k. I don't wait till I get the service warning appearing. That's just me being anal on maintenance though. I've always believed if you give your car the proper maintenance it will last you longer
If you read your owners manual (maintenance) schedule, I believe it says you should change your spark plugs at 50k, but it's up to you though
Thanks tho'.
My Ride: 2004 Dinan 545i, Titanium Metallic Silver, 2007 Dinan M5, 6sp, Silver Gray Metallic
I had a misfire in cylinders #1 & #3 that cause a slight hesitation every now and then (60k miles), I changes the plugs and problem solved. She runs like a dream.
EuropeanArtz
Sep 23, 2015 08:21 PM
