Help!!! Fellow 530i owners w/ sport package.
Old Feb 24, 2005 | 05:51 PM
CENTRAL CALI's Avatar
My Ride: -SOLD- 530i Alpine White. Sport package, comfort seat package, premium sound package, power rear shade, premium package, rear red reflectors, and adaptive headlights with xenon’s
Thumbs down
Help!!!!!! :bashwall:
This is the front driver side measuring almost 26 ? inches from the ground. The passengers side is measuring 25 ? from the ground as you can see in the other pictures. I was wondering what other 530i?s with sport package was reading to see what side is closer to being correct.
I was washing the car and putting tire dressing on when I noticed that the gap was different between the two sides. I?m not sure if it a spring defect or if something is wrong with the suspension.
Can someone measure so I can tell the dealer what I think is wrong.
Thanks guys and girls you are the greatest.
Help!!! Fellow 530i owners w/ sport package.-dsc00527.jpg
This the close up of the drivers side at almost 26 1/2
Help!!! Fellow 530i owners w/ sport package.-dsc00528.jpg
This is the passager side
Help!!! Fellow 530i owners w/ sport package.-dsc00529.jpg
This is the passagers side close up at 25 3/4
Help!!! Fellow 530i owners w/ sport package.-dsc00530.jpg
Central Cali
Old Feb 24, 2005 | 06:42 PM
mp0i's Avatar
My Ride: 2005 530i SMG, Sport package, Premium package, L7, Xenon Headlamps, Window Shades, Rear red reflectors
Originally Posted by CENTRAL CALI' date='Feb 24 2005, 07:51 PM
Help!!!!!!? ? ? :bashwall:
This is the front driver side measuring almost 26 ? inches from the ground.? The passengers side is measuring 25 ? from the ground as you can see in the other pictures.? I was wondering what other 530i?s with sport package was reading to see what side is closer to being correct.?
I was washing the car and putting tire dressing on when I noticed that the gap was different between the two sides.? I?m not sure if it a spring defect or if something is wrong with the suspension.
Can someone measure so I can tell the dealer what I think is wrong.?
Attachment 5343
Attachment 5344
Attachment 5345
Attachment 5346
Central Cali?
[snapback]94106[/snapback]
I did a quick check of my 530i with the sport package and got:
Driver Front--26 5/8
Passenger Front -- 26 3/4
I am not sure what to think. Are the tire pressures the same?
Old Feb 24, 2005 | 07:03 PM
Post
Mp0i,
Good question, the car was in the shop (BMW) this afternoon for the first oil change at 9,500 miles and they even checked the air pressure in all 4 tires, at least that is what the work order stated. On top of that I have the noisy Dunlop R/F tires so I don?t think it would change the height to much.
Thanks for checking the measurement for me, I really appreciate it.
I?m not sure what the deal is then. It looks like it could be a bad spring then or something bent on the suspension. I can't remeber hitting any pot holes or something that could have caused this.
Central Cali
Old Feb 24, 2005 | 07:57 PM
DXXXi's Avatar
My Ride: 530i, Silver Grey, Black Dakota, Steptronic, Premium, PDC, Logic7
I remember reading a very similar post about a year ago on RF. I think it ended up being something to do with the active steering and the fellow was told it was normal - i.e. within tolerances. Don't remember what the comparable numbers were but 3/4 inch seems like a lot in your case.
Old Feb 24, 2005 | 08:54 PM
EBMCS03's Avatar
Have you tried parking on a different spot in your driveway? on My dads car the front wheel gap measures differently in our driveway which looks perfectly flat but clearly isnt the case.
Old Feb 24, 2005 | 09:59 PM
TitaniumGray5's Avatar
My Ride: '05 545 Sport Week 9
All BMW's are slightly higher on the driver's side to adjust for the weight of a driver on the suspension. Try measuring with 150 lbs in the driver's seat and you should be about even.
Old Feb 25, 2005 | 03:18 AM
300TTto545's Avatar
Originally Posted by TitaniumGray5' date='Feb 25 2005, 12:59 AM
All BMW's are slightly higher on the driver's side to adjust for the weight of a driver on the suspension.? Try measuring with 150 lbs in the driver's seat and you should be about even.
[snapback]94173[/snapback]
Agree - and not just with BMWs
Old Feb 25, 2005 | 04:51 AM
Originally Posted by 300TTto545' date='Feb 25 2005, 04:18 AM
[quote name='TitaniumGray5' date='Feb 25 2005, 12:59 AM']All BMW's are slightly higher on the driver's side to adjust for the weight of a driver on the suspension.? Try measuring with 150 lbs in the driver's seat and you should be about even.
[snapback]94214[/snapback]
[/quote]
Cool, I'll try that later on today and get back to you guys.
Central Cali
Old Feb 25, 2005 | 12:29 PM
Canada545's Avatar
Originally Posted by CENTRAL CALI' date='Feb 25 2005, 07:51 AM
[quote name='300TTto545' date='Feb 25 2005, 04:18 AM'][quote name='TitaniumGray5' date='Feb 25 2005, 12:59 AM']All BMW's are slightly higher on the driver's side to adjust for the weight of a driver on the suspension.? Try measuring with 150 lbs in the driver's seat and you should be about even.
[/quote]
Central Cali
[snapback]94236[/snapback]
[/quote]
The don't factor in having a pasenger?
Old Feb 25, 2005 | 01:43 PM
rollee's Avatar
the typical passenger is usually a female.
if she is 150 lbs or over, you might have a bigger problem on your hands than suspension height...
