HELP - E60 not starting - is it the CAS module ?
My Ride: E60 520d LCI
Hi, Iīm having a weird issue with my E60 - 520d LCI not starting.
Syntoms:
- Red steering lock warning ( I tried to clear it with Tool32, comes back instantly ).
- When engine is cold, I can start it without any problem.
- When engine is hot, inserting the key makes the radio come on. Pushing start causes relays chatter in the boot, no lights on dash, nothing else.
- If I unplug the battery and plug it again, engine can be started without problems.
- When I remove the key from ignition, the steering lock does not engage, nor the central locking opens as it should.
Reading this and others forums, I canīt make my mind if itīs the CAS module, the IBS, or something else ...
Any help appreciated !
Syntoms:
Syntoms:
Syntoms:
Thanks !
I was 80% sure that it was the CAS, but I could not find any mention to the relay chatter and the unplug/plug solution anywhere else, so I was still thinking that maybe it was an unrelated voltage issue.
Will send my CAS to get fixed.
TPIOlds
Mar 16, 2026 09:16 PM
