Help! Crank but no start issue
Old 05-30-2020, 02:54 PM
seanjordan20's Avatar
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Your DME is damaged. The codes are pointing you there I would get it repaired
Old 05-31-2020, 07:36 AM
scottalexander's Avatar
My Ride: 528i
Model Year: 2010 528i e60
Engine: N52k
What kind of quotes have you been receiving to fix your DME?
Old 05-31-2020, 08:28 AM
tfish1's Avatar
a local company says usually around 200, but they are the ones that mentioned usually its a misfire code not a no start condition
Old 05-31-2020, 08:33 AM
Model Year: 05 530i
Engine: 3.0 M54
You can try this company
Old 05-31-2020, 09:52 AM
tfish1's Avatar
After a cleaning and reconnect to test if it could fire up, alternator message is from a loose negative connection
Old 05-31-2020, 10:22 AM
My Ride: 528i
Engine: N52k
Its fair to say regardless of the myriad of fault codes that are surfacing or will surface in the future, if your DME is missing a pin and it has corrosion on other pins, its time for a DME solution.
There might be a range of problems with your car, but we know one thing for sure. The DME is damaged and is at the top of the priority list to get fixed.
Old 05-31-2020, 12:20 PM
tfish1's Avatar
lol this we can agree on for sure. I'm just troubleshooting and assuming that the dme is fine and whar would my next step be
Old 06-11-2020, 08:14 AM
tfish1's Avatar
Got the call back saying DME couldn't be repaired, what are my other options?
Old 06-11-2020, 09:30 AM
Model Year: 05 530i
Engine: 3.0 M54
Did they reply and let you know if something was wrong with it or just sent a generic response
Old 06-11-2020, 01:35 PM
tfish1's Avatar
sounded pretty generic as their reviews say
Quick Reply: Help! Crank but no start issue
