hi
i buy a 2005 530i and it didnt read a mp3 disc i want to know if i update a idrive it can read mp3 ? i want to konw can i downlaod a Update disk and update it by myself ? if yes please send me a link of it? thanks |
if you do not have the Navigation/Sat option in yr i-drive, unfortunatelly you can not play mp3 discs.
Originally Posted by Roptor' post='409066' date='Mar 31 2007, 11:38 AM
hi
iam sorry the link that i post lated is incorect this link is correct i see they can update their progman themelvs ...is it right???
http://www.x5world.com/navigation-system/2...nload-here.html and this is it right ??? http://www.bimmerboard.com/forums/posts/29257 |
i want to know if you mean that screen in the front or somthing else??? |
Originally Posted by Roptor' post='409364' date='Apr 1 2007, 09:07 AM
i want to know if you mean that screen in the front or somthing else??? The links you provided refer to a different bmw computer. So far I don't know of anyone who has been able to update their computer software in the e60 from a CD. This is being done by the dealers or by yourself if you can invest in several thousand $$ worth of diagnostic computers. To your mp3 question, yes this is possible and not relevant to the fact that you may or may not have navigation/sat in your e60. I don't have Nav/Sat in my e60 and I can play mp3s. It is an option related to the Progman version and your dealer can enable it. Before you go into this process to update your car software do a search in this forum for instructions as to how you should burn an mp3 CD. Good luck |
thanks i found out why i cant play mp3 disk becuse my progman is old and i must update it ....
i think i have navigation becuse whene i start my car in desplay says " Please Insert DVD map.." is it mean that i have Navigation /sat? |
i think i have navigation becuse whene i start my car in desplay says " Please Insert DVD map.." is it mean that i have Navigation /sat? Sounds pretty strange to me. :confused: Anyways, If you have NAV, you will have 2 CD/DVD Slots in the centre console (under the i-drive screen) and one will be labelled 'DVD'. Now the question is if you have Business or Professional Nav. This depends on the fact if your i-drive screen is full width or you have a smaller screen with black bands at each side. Cars with the full width screen have Nav Pro, smaller screen means Business Nav (i.e. no full map display). With regards to MP3 Playback, it depends. Cars with Nav Pro can definately play MP3's. Business Nav or Non-Nav cars can only play MP3 if they you have the premium radio (i.e. 2 tuners - idrive shows a tab called ' All Stations ' in Entertainment/FM). All you need is a software upgrade at the dealer (but you must ask for MP3 to be enabled as it is a Retrofit Procedure they need to carry out). To get a software upgrade (if you are under warranty) tell the dealer that you are having problems with the i-drice crashing/re-booting, cd spinning while car is off etc. But don't ask for a software upgrade as the dealer may become suspicious at that time. Hope this helps. |
thanks i understan.thanks i serch all the internet cant find anything . but i have 1 CD dirve .
i must update it ... bye |
