Help with CIC retrofit 2006 E60 cant read cic module
My Ride: 2006 BMW 525i
So far I have added $609 $6VA and removed $663 from the FA as well as changed build date to #0909. I was able to write the new FA to both the CAS and LMA module. The trouble im having is this:
Once everything is connected The display does not turn on, the CIC buttons are illuminated but thats it. I tried to read the CIC module but I cant connect to it for some reason, I can connect and read all other modules.
kane1111
04-10-2015 04:40 PM
