HELP: Car Won't Start
![Exclamation](https://5series.net/forums/images/icons/icon4.gif)
I hadn't driven my car in like 3-4 weeks. It was working just fine prior to that. I go to start it and no go.
Headlights turn on, console lights, radio, etc fine.
Battery measured 11.6v. So I'm like hmm I haven't driven it in awhile, maybe just needs a charge. I put it on the charger over night and it charged up and no error codes from the charger.
Put the battery back in and still no start.
- Nothing dims when attempting to start
- Car doesn't try to turn over
- All I hear is one click when I push start
My Ride: E60
Model Year: 2010
I had a similar problem. Sadly it did turn out to be the starter.
I took a long pole, poked it between the intake manifold to reach the starter, and gave the starter a good hit while attempting starting. (Would need 2 people). This should be a last resort.
If this works, I would recommend a new starter. I believe you can replace components, however, in my case, I found it easier to replace it due to the age and mileage of the car.
Also...
Have you checked to see if any loose terminals?
Any blown fuses(Check #7 or #15 in the glove box) or any other engine management fuses.(I checked all my fuses with a tester)
In my case, the car is used daily..it just died on me one day. Never gave any trouble in the past, nor any signs of deterioration eg, long cranks..etc
Also...
