HELP -- Car is not aggressive enough when warm.
Old May 13, 2015 | 09:54 AM
Tigr's Avatar
My Ride: BMW E60 530d 2004
Model Year: 2004 Apr
Engine: M57N
Default HELP -- Car is not aggressive enough when warm.
Hi guys. I have BMW E60, 530d, 218PS, 2004, 317.000km. When cold, everything is fine, I am touching a little the accelerator pedal, and car is starting to fly at the same moment.
But after some minutes, when car is warmed up, situation is changing. The TURBO-charger is not starting to work so fast/easy, I have to push the pedal hard, then wait for 2-3 seconds, only then TURBO-charger is starting to work.
It seems that some valve is not opening when warm... Could anyone explain me what is happening?
Thank you.
Old May 13, 2015 | 10:39 AM
Anzafin's Avatar
My Ride: Bmw 530d 2004
Could be a clogged DPF (diesel particle filter). Read this:
https://5series.net/forums/diy-do-yo...nce-dpf-94725/
Start by reading the error codes.
- Antti -
Old May 13, 2015 | 11:52 AM
Tigr's Avatar
Engine: M57N
Antti, thank you for your answer.
There are no error codes! But it is stinking very ugly from the bottom of the car.
Old May 13, 2015 | 12:07 PM
ripley's Avatar
My Ride: 2007 E60 530d
Engine: M57
So when it heats up it runs badly and there is some dirt/soot/oil around the engine near the turbo?
Have you got a crack in something like an exhaust manifold?
Maybe wash it and see if you can spot something while it is running when warmed up.
Old May 13, 2015 | 01:36 PM
Tigr's Avatar
Engine: M57N
Yes, it runs badly when it heats up. There was black dirt/soot around the turbo because of bad gasket at the connection point "exhaust manifold to turbo", but that is fixed. Had driven like this very long time.
Before I bought this car 5 years ago, I guess the Turbo of it was changed, and they did not put 1 of the fixing bolts at that connection point. I found it recently because of that dirt around the Turbo.
Old May 13, 2015 | 02:27 PM
ripley's Avatar
Engine: M57
Assuming all the vacuum lines are attached properly maybe its worth looking at the vane actuator (vacuum) and vanes. Are they getting stuck?
Might need to observe running cold then hot.
What do you mean by "stinking very ugly" exactly.
Old May 13, 2015 | 03:15 PM
Tigr's Avatar
Engine: M57N
When I open front windows I immediately fill sour, rotten smell, but no smoke!
Old May 14, 2015 | 11:19 AM
Tigr's Avatar
Engine: M57N
Default DPF or not?
I just had another thought: if it is DPF, why the car runs normal after some seconds I push the pedal? It just take time and more effort to make TURBO to start. Then car is OK. And why there are no error codes?
Old Oct 9, 2015 | 04:49 AM
Tigr's Avatar
Engine: M57N
- Antti -
I was driving to Switzerland from Belgium 2 weeks ago. My car lost its power. It was not possible to drive it faster than 110 km/h on the horizontal highway. Whenever the road was going up-hill the speed was dropping down to 70-80 km/h max. I was forced to turn back and visit a garage. Car diagnostics showed no error codes. So they assume that it is my DPF. They took out the full exhaust, checked the "catalizator", which was perfectly clean. But the DPF was clogged. So they made 24mm diameter hall in it. The car is fantastic aggressive and fast now.
Plus; I did not got the "Car is not aggressive enough when warm" problem up-to now.
The only question is: will the car pass the German technical control with such a hall in DPF or not? (I have no error lights on my dashboard, just when you do a computer diagnostics of the car, there is an error of DPF sensors wrong temperature.)
Attached Thumbnails HELP -- Car is not aggressive enough when warm.-img_6120.jpg
Old Oct 9, 2015 | 01:20 PM
ripley's Avatar
Engine: M57
Will it pass TUV?
Maybe not after the Volkswagen fiasco.
Also why only one hole?
Wouldn't it be better to make a hole or holes the same size as the pipe into the DPF.
rackhacker9275
May 11, 2018 04:05 AM
E60I
Mar 21, 2015 06:24 PM
coops
Oct 7, 2003 04:45 AM
Aug 15, 2003 07:38 AM
