Help - adjusting PDC volume? (LCI)
Old 11-04-2007, 10:40 PM
bruce_miranda's Avatar
Originally Posted by Russ1974' post='489915' date='Nov 4 2007, 11:07 PM
Doesn't work on my car. The beep stays the same volume and the stereo volume goes up and down... anybody else tried it??
Try with everything else muted and just the PDC on.
Old 11-04-2007, 11:28 PM
525d MSport's Avatar
Russ,
Turn the radio off first, select reverse and then adjust the radio volume knob.
I tried it this morning and it does work.
Let us know if it works for you.
Regards,
Old 11-05-2007, 12:53 AM
///Marco.it's Avatar
Model Year: 2012
+1, I have the same problem and I tried many times with no luck. Will try one more.
Old 11-05-2007, 01:01 AM
ipp
ipp's Avatar
My Ride: 07' 530d - M-Sport - Titanium Silver / Black Dakota leather 08' 120i - M-Sport - Alpine White III / Black Sensatec
Originally Posted by 525d MSport' post='490114' date='Nov 5 2007, 09:28 AM
Russ,
Regards,
Do you have nav?
Old 11-05-2007, 01:13 AM
Originally Posted by ipp' post='490129' date='Nov 5 2007, 12:01 PM
Do you have nav?
No I don't.
You need PDC to be beeping before you adjust the volume.
Regards,
Old 11-05-2007, 01:55 AM
Russ1974's Avatar
My car is in the garage until Wednesday, I'm heading off to London for a couple of days so dropped the car off this morning and said "STOP MY BRAKES SQUEAKING" very politely, honest. I will try it as soon as I pick it up. When you say "switch the radio off", do you mean "mute", as it's not possible to switch it off.
Perhaps it only works on cars without Nav ... if nobody else tries and posts results here before Wednesday, I will do so.
Old 11-05-2007, 02:01 AM
Yes I do mean "mute".
I will have a play with it lunch time and see if I can write a bit more concise description.
Regards,
Old 11-05-2007, 02:42 AM
hondik's Avatar
My Ride: E61 CarbonBlack 535d, Ventilated and Heated Comfort Seats with Massage in Black Nasca Leather, Dark Poplar Wood, Professional Navi, Folding Rear Seats, Load Through, Advanced Remote, PDC, Bluetooth, Dimming and folding Mirrors, Bi-Xenons, Hi-Fi, Tinted
Doesn't work - tried volume knob with mute on.
Old 11-05-2007, 04:57 AM
Regards,
OK here goes:
Put something real close to one of the front sensors, get in car, start engine, radio off (mute), press PDC button, keep in neutral.
PDC beeps and display is red. Turn radio volume knob clockwise to increase volume, anti-clockwise to reduce.
I did this just 2 minutes ago and there are at least 3 different volume levels.
Regards,
Old 11-05-2007, 10:21 AM
kscarrol's Avatar
My Ride: E90 M3
Model Year: 2011
Originally Posted by 525d MSport' post='490204' date='Nov 5 2007, 07:57 AM
OK here goes:
Regards,
Interesting, just tried mine but no luck. The difference is I had the radio on. Perhaps the radio on overrides the operation of volume control on the PDC. Will try again later with radio off (er, sorry Russ, muted...).
Quick Reply: Help - adjusting PDC volume? (LCI)
