Help Adaptive light failure
Old May 10, 2008 | 11:35 AM
kjhkent's Avatar
Hi
Went to the car today. after a few seconds an error message was showing stating that there was a cornering light failure. I understand that this is a problem with the adaptive lighting. I have complained in the past of water inside my headlights. I was told that the headloghts were resealed. Despite this with the least bit of rain I can see water covering the inside of both headlight lenses,rather than just slight misting. I thought I would check the fuses and found that there is no fuse card in the fuse box. I would appreciate any advice on this. Its booked into the dealers for next week, but I am sure they will want to muck about trying to reseal the headlights. Has anyone got a clue as to getting a relacemnt fuse card.
2006 530 D M Sport 18000 miles. Stl in warranty
Old May 10, 2008 | 11:40 AM
Tacklebury's Avatar
My Ride: 2005 535d M Sport. Carbon Black, Black Leather, Sports Seats, Black Ash, Bluetooth, Auto Lights & Wipers, Navi Pro, Sunroof, Logic7, Anthracite Headlining, Heated Seats, Bi-Xenon�s, Twin DVD screens in the rear hooked up to a 10 disc DVD multi-changer, Clarion Wireless Headphones.
Warranty.....
Send it back and get a new headlight. My 530 (late 2003) had the same thing, ?800 later and BMW had fitted a new one, never had any problems since.
New car warranty must cover it if my Used and Approved did!
Old May 10, 2008 | 05:44 PM
ixsna's Avatar
Funny how you mention that my 05 is having the same problem. I have no moisture in the lamp not even an idiot lite. The passenger side lite is stuck shining off on the shoulder of the road. I can't even tell if the driver side is working either.
Old May 11, 2008 | 01:44 AM
jbsapphire's Avatar
Since its under warranty, get it replaced. Don't accept anything less.
Old May 11, 2008 | 02:42 AM
Etienne's Avatar
My Ride: May 2008 530D "M" package Exclusive line.
+1
Old May 11, 2008 | 10:12 AM
kjhkent's Avatar
Each time I take it back I get the "BMW accept a certain percentage of moisture in the headlight crap. I took it into the Sales manager as the service dept was shut and he has now seen how wet it gets. Its now going back with the following
1. Headlamps fill with water
2. Adaptive light failure
3. All door rubbers dry causing doors to rattle
4. Remote seems to have lost range will only open if I am near to vehicle.
Never the less still a great car. Hopefully all will be resolved next week.
Old May 12, 2008 | 02:03 AM
Dandle's Avatar
My Ride: 07 E61 530d M-Sport.
These are pics of my headlights misting up most of the drops of water you see are on the out side but there was still a fair amount inside too. BMW gave me the same story about a certain amount of moisture is normal but after emailing these pics they booked it in and it had two new lights fitted. Although they still have a slight misting if its really damp and the lights have been on a long time. At the end of the day Hella didnt design these lights to mist up and BMW didnt ask for that in the design either so something isnt right.
Old May 12, 2008 | 02:33 AM
Etienne's Avatar
Is it the word of your dealer or realy the position of BMW ? Try to have it confirmed !
Anyway, does your sales manager also accept a percentage of adaptative light failure due to this problem ?
So, at that point, the discussion with your BMW agent should be over.
Old May 12, 2008 | 02:38 AM
Dandle's Avatar
Its the official BMW line the service manager showerd me a technical document about it stating some misting should be considered normal and also the proceedure to confirm the headlight isnt leaking.
Old May 12, 2008 | 03:01 AM
Etienne's Avatar
Initially, Kjhkent talked about water and not traces of moisture / misting which anyhow let to resealing of the headlights.
Now water seams to be still a problem causing a failure.
As far as the car is still under waranty, I don't understand why the dealer is hesitating to proceed with a headlights change.
