Help - 535xi factory downpipe removal
My Ride: 2008 BMW 535xi, VRSF 5" FMIC and ChargePipe, TurboSmart Raceport BOV, BMS DCI, MHD Stage 1+. XHP Stage 3,H&R Sport Springs
Hello all,
First post on the forum, got my 535xi earlier in the year and have so far installed FMIC, Charge w/ BOV, DCI, H&R Springs etc. This is the first car I've done any of my own work on and as such has been a learning experience.
As soon as the 535xi downpipes were released from VRSF I purchased. So far I have my car up on four jack stands with the 02 sensors and exhaust side brackets of the downpipes completely removed. Downpipe on driver side is removed from it's bracket and it would be nice to pull it so I can get to the second downpipes bracket bolt. As a side note, plastic engine cover is off as well as the metal tray underneath it.
Right now I am trying to determine how to get the downpipe off the turbo vclamp with absolutely 0 results. I cannot determine what needs to be removed and I cannot visually locate where those clamps are. Unlike the tutorials I've watched/read (pretty much all of them for 1 and 3s) I can't access them, and I can't locate steering rack bolts either.
I'm thinking I need to remove the subframe or at least drop it but I have no way of knowing if that will grant the needed access.
My question for the forum, is:
if anybody has ever done one of these installs on a E60 with xDrive and how on earth they got access to the turbos.
There are 0 535i DIYs and even less chatter on the forums on how somebody might have installed on the xDrive platform.
Any advice would be greatly appreciated.
Engine: N54
I figured as much. Purchased an engine support beam. Now from what I can tell, the only mounting point to hold the engine at is the thread near the oil cooler where you can attach a mounting point from when the engine cover is off... if anyone can verify this.
A tad bit nervous about the whole process but it's what must be done.
Engine: N54
If you want to talk through this procedure with me I'll be happy to but it would take me forever to type it out on my phone so I propose a deal:. Call me and I'll talk you through it and answer any questions you have then you write it up and take pics as you go deal? 310.767.6659
