Help! 05 545i electrical craziness
My Ride: 2005 545i, 6 speed manual, sport package
Mods: RPi Exhaust, RPi Scoop, BMC Air Filter, CF Emblems
Driving my car and all of the sudden I got the following errors:
Dynamic steering ( lost power steering)
ABS warning ( lost ABS, scary)
iDrive screen went blank
Basically the car threw every error code at me possible.
I parked the car and it would not start. I purchases a battery from o'reillys and my car started right up. I had an Dynamic iDrive error but it went away after the second restart. Drove around for about 1 day when I was on the highway and my car went crazy all over again. Got it towed to my Indy shop but they are not open on Sundays. Could a faulty alternator be the cause? Please help!
My Ride: 2004 545i 6 speed, Silver Gray A08, Gray leather
Mods: Hard-Wired Passport 9500ix LIVE , K&N Air + RPi Scoop, Mtech V2.1 AE, ACS pedals+Ebrake, flip up front plate, OEM 172's, Custom M Kit, M3 shift knob, Eisemann Race Exhaust
2005 X5 3.0 (the nightmare)
1998 528i SOLD @ 173K
Sounds like the alternator to me....
Too bad you're not with the car now, as you could probably go into the hidden menu (instructions available using Search) and bring up the voltage display. This would give you the state of the battery, and then after starting, the state of the charging system.
Check your passenger floor in the front and also your trunk for water... if its not your battery or alternator i would bet there is water.
My Ride: 2004 545i: Silver Grey Metallic | Sports Package | | Cold Weather Package | Navigation | Tinted Windows | Adaptive Headlights | Heated rear seats| 166 rims| Matte black kidney grills|
Interior: Angel Eyes, LED license plate bulbs, HID fogs, Interior LED
Did you have your new battery programmed?
Exact same thing my '04 545 went through. I changed my battery late last year but still experienced these problems. Finally got the car checked out by the dealer... bad alternator.
Like the other members mentioned, check for water. Then check the battery. If it's not the battery, check the alternator.
Good luck.
Good luck.
+1 on alternator. If everything was peachy after the battery was installed, and then freaked out after using it for a while, I would think it would be a shot alternator.
Thanks for the input. Turns out I had a bad alternator. Should have my car back tomorrow and will let you know how it runs. If you own a E60 with around 70k I would get your alternator checked. It is not a lot of fun on the HWY when it goes out!
