Hello Newbie here
Hi I'm planning on getting a used 530 within the next month and I'm wondering if the i-drive screen is hard to see in the daytime? And if so can these screens be replaced with an aftermarket screen. SORRY if these questions are newbie tpye questions but I am one. I searched and didn't find anything about daylight readability on screen mods
welcome. there is no problem seeing the idrive screen during the daytime. the screen is enclosed so there is no problem. as for replacing it with an aftermarket screen, i tried to search and go through the topics because i remember a little while back when a member changed the screen and took out the whole enclosure. sorry i cant seem to find it, maybe someone else could. other than that, enjoy the forums.
I have a 8 month old 530 D. I have no problem reading the screen even in brilliant sunlight (when we get it in the UK)
The screen also has a sensor (see small hole under screen) that adjusts the brightness to make it readable in most light conditions. You can also adjust the brightness manually.
My Ride: 11 550i Sophisto Gray/Oyster Black/Anthracite, Sprt Trns, DHP, IAS, SP, PP1, PP2, CWP, HUD, DAP, AVSP, SF RS, CA, ACC - Euro Del
The screen is very bright and is fine from the factory. In the I-Drive menu you can adjust the brightness. I never found the need to adjust the brightness all the way up. The e 60 5 series is a great car. I am getting my second e60 shortly.
There is absolutely nothing to worry about seeing it under sunlight
My Ride: G30 M550i
Model Year: 2018
The central information display (CID) is perfectly visible -- even in direct sunlight. The term "transreflective" comes to mind -- not sure if that's the right term or not to describe things but just rest assured that you'll always be able to see the screen, regardless of the lighting conditions...
I usually turn it off so that I'm not distacted , Does anyone else ??
tgueno
27
Oct 13, 2006 11:17 PM
