Headlight Up/Down feature (Self Leveling) not working
Recently, I noticed that the headlight (xenon) up/down feature (self leveling) during start of the car not seem working. Headlight beam did not go up & down, it just stayed at one level. Any suggestion what to look for ?
Thanks, Ching-Ho Cheng |
does the led form the light switch blink green?
Originally Posted by stel_i79
(Post 1599055)
Thanks. |
Is it supposed to go up/down. Upon startup, mine go from left to right.
If it has an issue the light should be blinking. Mine has been blinking for about a year. Troubleshooting has been a headache and I gave up.
If yours is not blinking then it doesn't see an issue with the modules. |
Originally Posted by tstiglich
(Post 1599071)
(Post 1599076)
If yours is not blinking then it doesn't see an issue with the modules. Thanks. |
Not sure. But on mine, if I have the headlights "ON" vs "AUTO", they don't steer with the front wheels. Otherwise, they do the up/down when starting, then side-side.
The motors or broken guides
The system is checking itself when starting. If it sees something wrong it will start flashing on the selector panel
