Sponsored by:
Sponsored by:
E60/E61 Brake pads
Old 04-06-2015, 06:25 AM
vards01's Avatar
My Ride: E61
Default E60/E61 Brake pads
Hi all,
I have just replaced the front pads on my E61 and removed old worn pagid patten pads and replaced with genuine BMW pads, although the BMW ones do not have a spring prong fixed to the back on the opposite side to the caliper piston. Are there two types? I have searched ebay and all BMW ones listed seem to be the same......
I have fitted the pads and seem fine, but concerned there may be two types which are not interchangeable.
Thanks in advance.
Old 04-06-2015, 09:27 AM
seanjordan20's Avatar
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
No there is only one type that goes on the car. You have the right ones. It is not a spring it is there to hold the pad in place.
Old 04-06-2015, 09:33 AM
dingolfing's Avatar
My Ride: 2008 550i
I ran into this as well when I replaced my pads with ceramic ones. Although in my case, the pad metal retaining tabs meant to fit inside the caliper piston were a different size than my stock pad's tabs. So I ended up doing some transplant "surgery" and removing the stock retaining tabs and mounting them on the ceramic pads.
Funny thing is, I did some research and it appears the pads I purchased may have been meant for Euro-spec E60's.
If the pad fits correctly within the caliper mounts and it is the exact same dimensions as the old pad, you should be fine.
bestofthebest
03-28-2016 02:47 PM
ST JAMES
09-23-2015 11:13 PM
DetailersDomain
Detailing Forum
09-22-2015 03:59 PM
militantgrunt
09-10-2015 02:31 PM
turbo_mustang12
09-02-2015 10:46 PM
Quick Reply: E60/E61 Brake pads
