Headlight Problem
well, I didnt read everything, but when I saw the post that said the lights aren't tied into the suspension, then how do they know when to autolevel? BTW, be careful with the auto level system, the system that is tied into the suspension on Audi's is pretty sensitive and expensive for stupid little parts.
As far as adjusting them, have it done by a tech, don't bother trying to align them yourself. It's only $40 from the dealer. They don't do it manually, they just plug in and adjust which is the correct way to have it done.
My Ride: G30 M550i
Model Year: 2018
Good advice about having a technician adjust the lights. These things are so precise that adjusting them isn't something you do by trial and error...
My Ride: 2007 550, premium, sport, nav, bluetooth, satellite, cold, M5/Mtech front bumper and side skirts, matte black kidney grilles, M5 fender grilles, M5 mirrors, euro stickers, 35% tint, 20" Miro 111s (summer), 18" VMR VB3s w/ 10 mm H&R spacers (winter)
Originally Posted by Rudy' post='237786' date='Feb 10 2006, 09:04 AM
At first I was thinking that the lights had an internal or external sensor (like a mercury switch or something) that would detect when the car was level, inclined, etc. I'm sure there are a few ways to accomplish the vertical adjustments. As far as the adaptive lights, clearly they're tied to the steering system.
So I had the dealer readjust the level sensor the other day, but the left side still seems a bit low. The right side is fine. Based on Rudy's fantastic PDF instructions (thank yolu Rudy), I'm going to give the screws a shot for the vertical adjustment and see what happens. If it doesn't work out, I'm going to take it back to the dealer and have them reset. However, $40 seems like a pretty cheap charge for this. Is this a standard BMW charge for this adjustment or are they going to try and charge me the "hourly" rate, which is around $110.
My Ride: G30 M550i
Model Year: 2018
Originally Posted by Rudy' post='412904' date='Apr 12 2007, 05:29 PM
Be careful -- the left side is usually lower than the right (on left-hand drive cars) so that you don't blind oncoming traffic. Obviously, without seeing your car, I can't tell if what you're seeing now is normal or not so just be careful you don't end up adjusting things and then blinding people...
That's why I said it's easier to just find another E60 that you know is aimed right, and mark the spot, or do it prior to the drop.
ricki_
12
02-08-2020 09:50 PM
ASpec818
11-30-2015 04:14 AM
kurtb23
04-22-2015 04:30 PM
rizwan1377
04-05-2015 05:22 PM
