Headlight lens removal
#21
If you can remove the bulb, then just fashion a wire coat hanger or something to reach through the hole and pull the socket back into place and then glue that bad boy in.
#22
My Ride: 528I E60
Model Year: 2009
WOW
Thank you, thank you, thank you, DanL. Just the info and pics I was looking for. Hopefully with this and the advice from Donpb about the coat hanger, we can do this. Thanks again.
![W00t](https://5series.net/forums/images/smilies/imported/w00t.gif)
#23
My Ride: 3-'06&07 530xi, 1991 Dinan 850TT
Model Year: 1991
Other bad news is- the old side is not going to look new! Might have to buy a pair!! Junkyard would be my first option.
#24
My Ride: 528I E60
Model Year: 2009
Thank you for that idea!!! It's worth a shot. Especially it saves us from purchsaing a new headlight assembly. Thank you again.
#25
Model Year: 1991
I think you can fix it with some wire thru bulb hole to grab it. I would suggest a smaller gage and a little more playable wire than coat hanger.
Position the assembly where gravity is to your advantage to bring the lens in place.
Dexterity! Good luck.
#26
#27
My Ride: 2008 550i
I reattached my cornering lens using double sided tape, all thru the bulb opening hole above. It's tricky, but is doable and doesn't require purchasing a new assembly.
donpb (08-03-2020)
#28
Argh. I just got a right parking lamp notification and its the angle eye bulb. I have replaced that bulb already so not sure if it went bad or the wiring shorted. When I was in there last time, several wires were exposed and I lamely taped them back using blue painters tape. Yeah yeah I did not have electrical tape at the time.
So now I have to go back in there and thanks to that third video, I think I can do it easier this time without scuffing my bumper up like I did before. I did not know about the pull forward first part. I will make sure to do that this time but I'll still put some tape there to protect the bumper just in case.
#29
just did this repair a few months ago. I decided to remove the lens completely, replaced the lens (epoxy) blacked out headlights, and replaced the halos. would be a great time to retrofit some nice projectors for upgraded lighting but money was tight at the time. Have some morimotos for next time.
fresh1991
12-19-2011 04:23 AM
