Headlight Fuse (fusebox)
My driver headlight has been flickering then turning off, and only driver side is doing it. Going to check out the fuse for the headlight since I heard that the driver and passenger side have separate fuses. Anyone know where the fuse box for headlight is located, can't find my manual to look it up. (2008 535i)
If the fuse checks out ok, then it is probably a wiring or ballast issue, tried my working passenger side bulb on driver side and same issue so its not the bulb.
Vman33
03-14-2022 04:43 AM
umnitza
11-25-2015 11:10 AM
Bogdan7
09-23-2015 11:40 AM
