Headlamp eyebrow LEDs not working?
Old 08-14-2008, 06:24 AM
*AL*'s Avatar
My first question on here.Should these LEDs illuminate when you switch the lights on? I believe the LEDs are marker lamps? I've noticed mine don't illuminate on either side I've noticed a few E60s where some are working and on others they are not? Can anyone shed some light on this? I'd like them to be working, and could take a feed off the side light circuit but want to check first just incase i've missed something?
Cheers Al.
Old 08-14-2008, 06:25 AM
tonymac's Avatar
This topic has been brought up before. Try using the search bar on the top right. It is a great tool.
Welcome to the forums and god luck
Tonymac
Old 08-14-2008, 06:39 AM
*AL*'s Avatar
Just done a search but can't find the answer i need? Do they turn on with the headlamps?
Old 08-14-2008, 06:41 AM
Gene's Avatar
Al, which light are referring to?...by the blinker or above the ae's?
Old 08-14-2008, 06:43 AM
*AL*'s Avatar
The little row of LEDs which also illuminate the brow above the lights.I think 4 LEDs per side.
tonymac's Avatar
I am pretty sure he is talking about the eyebrows...
Tonymac
Old 08-14-2008, 06:45 AM
*AL*'s Avatar
Tonymac
Yes i guess they are the 'eyebrows'?...........mine don't work either side.
Old 08-14-2008, 06:46 AM
Bteljuice's Avatar
i think its a well known bug, u need a software upgrade to fix the problem.
Old 08-14-2008, 06:47 AM
tonymac's Avatar
You might want to edit the title to something saying eyebrows so that the experts can chime in... I will also look to see if I find something for you..
Tonymac
Old 08-14-2008, 06:48 AM
Gene's Avatar
depending on the year of the e60...on pre-LCI e60's there is a software update needed to turn on the eyebrows. They should come on with the parking lights and headlights. Again, if you run a search on via "eyebrows" you will find a few threads on it..GL
eyebrows: orange lights on the top outter corners
Quick Reply: Headlamp eyebrow LEDs not working?
