head up display too low help...
Old 05-10-2007, 12:19 AM
Tiago's Avatar
My Ride: 535d
Model Year: E61 2006
Originally Posted by stanatl' post='422484' date='May 9 2007, 12:57 PM
There is a service procedure (see attachment below) that can adjust the HUD level. My understanding is that it can only be moved an inch or two but that might be enough.
If this doesn't work there is a special bmw tool that can adjust the HUB manually.
Old 05-11-2007, 07:39 AM
mkaresh's Avatar
Well, this certainly explains a lot.
I've driven some HUD-equipped BMWs at the Komen event, and the numbers are always clipped for me. I've spent many minutes searching for an adjustment I assumed have to be there. All GM cars with HUD have a switch for this.
And yet, BMW with an iDrive to provide dozens of adjustments for things I never thought needed adjusting, doesn't include this? Different height drivers are going to want the display at different heights. It should be keyed into the memory seat. That you need to go to the dealer for the adjustment is nuts.
Old 05-14-2007, 05:33 AM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Okay, I think I figured out why I thought the HUD might be adjustable via the iDrive controller...
The E70 (new X5) has that feature. Somehow I must've learned that and thought that the LCI E60 cars had it too.
At least we know that BMW is addressing the feature -- it just may not make it to the E60 but will likely be on the F10!
BrandonSS
04-19-2016 05:11 AM
umichchris
12-07-2015 03:33 PM
carid
08-07-2015 03:09 AM
e60fans
07-27-2015 04:52 AM
Inty
07-09-2015 09:48 AM
Quick Reply: head up display too low help...
