Head unit not programmed correctly
I just bought a 545i and notice when I turn on the car the head unit reads: HEAD UNIT NOT PROGRAMMED CORRECTLY! What should I do to get it working properly. Other than that, car runs great. Any help will be greatly appreciated,
Thanks |
Was it doing that before you bought it? Sounds like somebody attempted to code it and botched up somewhere. Is it a Nav or non-Nav equipped car (easy way to tell - single disk slot or dual disk slots)?
I'd like a picture of that one.. new one on me
Originally Posted by black knight
(Post 1514680)
Thanks |
Just get someone with a optical device (OPS, etc) to reprogram or just take to the dealer and have the entire car updated.
there is a relay in the trunk under the spare tire. I spilled a bucket of water in the trunk one day {dont ask how ] and that relay shorted out. That relay controls cd/radio/head-up dispay. For 100$ you can get a new relay from a salvage dealer.When changed the relay, everything working now but at start up it says head unit not......
Originally Posted by chrisgo
(Post 1517879)
Hmmmm....curious as to if the OP resolved this. No response in over a month?
Its been years since the last post, but for reference, anyone out there stuck with this message, here's how I fixed mine.
This error suggests that the idrive is partially programmed/updated. Updating the head unit is a long process and requires several ECUs to be flashed. To remove the error, make sure all of the related ECUs are flashed with the same daten version and all have the correct VIN. The related ECU list can be a bit of a challenge to find in INPA. The ones that I updated were: MOSTGW, MMI/CCC, VIRTSG90, VIRTSG91. It was easy for me to find as my head unit was replaced by a 2nd hand unit and I picked all the ECUs with the previous vehicle's VIN to update Hope this helps! |
Help please !
Hello everyone! I have a 2005 545i that has an error on the screen saying the head unit is not programmed correctly. I recently replaced the alternator because that’s what we thought was the problem. Before thinking it was the alt we connected the battery and got a jump and it turned on. Then we disconnected the cables from the jump and the car turned off we we were sure it was the alt. After replacing the alternator the car gave the code and still does not turn on. Help please ! |
| All times are GMT -8. The time now is 04:51 AM. |
