Head Light
Old 06-15-2009, 09:52 AM
bmx
bmx's Avatar
Can someone tell me what's the second lamps (inner) on the head lights are for? I thought they're high beams but nothing.
Old 06-15-2009, 09:54 AM
CWS530's Avatar
Flash to pass lights on pre-LCI.
Old 06-15-2009, 01:03 PM
BlaSTiWi's Avatar
On the LCI it depends ... where are you located?
If it has frosted lens then its cornering light but if its clear (like projector similar on the outter) it's for nothin' ...
Old 06-15-2009, 01:32 PM
bmx
bmx's Avatar
yes, the second inner projector type.
Old 06-15-2009, 01:58 PM
BlaSTiWi's Avatar
In that case it's not for anything ... it's just look like a lens... based on that you have LCI and seems to be not US market... if guess correctly.
Old 06-15-2009, 02:19 PM
Kzang's Avatar
I asked the same question 2 or 3 days ago. if you have the LCI car then the inner light is additional cornering lights when your using the blinker and at low speeds.
http://forums.e60.net/index.php?showtopic=78904
Old 06-15-2009, 02:28 PM
BlaSTiWi's Avatar
True if you have Adaptive Headlight option (which true for US market) but at some other market it does nothing ... other than the AE/halo ring light up ... the difference is the AHL has frosted cover while the non-AHL just simply look like projector lens.
Sample pic of non-AHL LCI:
Kasmo
05-07-2019 03:30 AM
TexaZ3
05-06-2015 09:54 AM
nsiu
02-04-2004 02:09 PM
zag
01-26-2004 12:16 PM
08-12-2003 11:41 AM
Quick Reply: Head Light
