The great EQ logic7 topic
on a side note it seems that concert settings is the way to go on most topics. Not many people like theater with i find strange as it seems on most topics theater is the settings that give the sound coming most from the front windshield witch basicly should be a good thing
My Ride: 2005 545i (SMG)
Titanium Gray
Black Interior, Anthracite Trim
M-tech kit
Sport Package
Premium Sound
Satellite Radio
Active Cruise
Comfort Seats
Navigation
Folding rear seats
Agreed, and I know from your many posts on audio that you know what you are talking about, but I wonder how many of us are really that interested in car audio competitions, significant aftermarket mods or RTA meters - but are basically happy with what we have but like tweaking it a little by trying out some other users' settings?
I was simply trying to make a point, which is that any time you change your CD... your ideal EQ settings will instantly change. For this reason, it's not going to be very beneficial to copy someone else's settings.
a certain comments on most topics about the eq seems to be a V shape settings might be the way to go as voices seems overdone by the system?
1. In competition, you are graded on the consistency of your EQ curve. This means that they use an RTA meter and get a graph of your EQ curve. The smoother the curve, the higher your score. A perfectly flat curve would get a perfect score.... but so could a V or U shaped curve, so long as there is never a step up or down of more than one LED light. (The Audiocontrol RTA meter is standard IASCA issue, and it uses LED lights to draw the RTA curve)
AudioControl Brochure
This is a link to the brochure for the Audio Control RTA meter which is the industry standard in competition car audio. If you look at page 2, you'll see how it displays an EQ response curve. The curve shown is a very poor one. This is because there are numerous points where the curve shifts by more than a single LED light increment up or down. An ideal curve can have some up and down movement, but it should not exceed a single LED jump at a time. If you look at the left side, you'll see that the bass is EQ'd way down... and then the levels rise quickly moving to the right. The increments there are 2 LED positions at a time, so this would score poorly. You'll also notice that the signal gets clipped at the top of the meter about 1/4 of the way over to the right. This would be bad, also.
2. The other reason is that the human ear is most sensitive to midrange sounds. High range and deep bass sounds are harder to hear. However, stereo speakers are very efficient at producing midrange sounds. For example, a midrange speaker does not require as much amp power and a subwoofer. A tweeter needs even less power than a midrange.... but it's harder to hear, also.
So, you'll commonly see EQs with a dip in the midrange to compensate for the ear's sensitivity to those midrange sounds... and for the efficiency of your speakers. Sub bass and tweeters commonly need boosting.
Titanium Gray
M-tech kit
Sport Package
Premium Sound
Satellite Radio
Active Cruise
Comfort Seats
Navigation
Folding rear seats
But, that's just how my ears hear it.
[snapback]97948[/snapback]
Titanium Gray
M-tech kit
Sport Package
Premium Sound
Satellite Radio
Active Cruise
Comfort Seats
Navigation
Folding rear seats
Ok thanks very helpfull. I understand. So in theatre the band is all packed together playing and the gitar man and drummer are standing in the same spot? and concert hall they stand 2O feet away from each other so you can point your finger at the spot they are playing on the stage. Is that how you mean it?
But to answer your question, yes. I hear the sound as coming from a wider field on Concert Hall than with the Theater setting.
[snapback]97953[/snapback]
incoherent
04-15-2015 04:48 PM
