Gradual increase in oil consumption
I've noticed a steady increase in oil burning over past couple years. 1200-1300 miles between adding quarts a couple years ago to now 700. What are the most likely suspects? Seems to be more consumption/burning than leaking while idle because at one point recently it was not driven for awhile and I noticed no change in oil level at all. Plus this decrease in oil efficiency has been remarkably steady and gradual.
2006 525XI, 140,000 mi, and I use 5W-30 synthetic.
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Remove under carriage cover and check to see if there's oil on the bottom of the engine. You'll know immediately because oil will be on the covers. Check front of engine from top to bottom. Crank shaft seal is a very known leak spot on the N52
The n52 is definitely burning oil. I have 211,000 miles and every 2-3 k I need to add a half quart. Try adding liqui moly ‘oil saver’ at oil changes. There’s no leaks that bad I’m sure
