GearBox oil
Old 08-20-2009, 02:26 PM
Dark Master 12's Avatar
Thumbs up
Hello there
where can i find the gearbox oil tank ??
i need to check it out
Old 08-20-2009, 03:18 PM
krusir's Avatar
My Ride: 2009 535xi, short shifter, no CDV
gearbox oil???
Rear Differential?
Manual Transmission fluid? or Auto Transmission fluid?
X-Driver Transfer case?
BTW, anyone notice that we don't have drain plug in rear diff. ( you will never need to replace according to BMW. ) Seems I only see fill pulg in e60 rear diff. It will be sucks if we need to use sucker to suck it.
Originally Posted by Dark Master 12' post='983942' date='Aug 20 2009, 03:26 PM
Hello there
Old 08-21-2009, 10:07 AM
uheenada's Avatar
My Ride: 2005 545i SMG
Originally Posted by krusir' post='983980' date='Aug 20 2009, 04:18 PM
gearbox oil???
Rear Differential?
Mine does. My indy mechanic drained and filled MT fluid and differential fluid in like 30min.
Old 08-21-2009, 01:04 PM
i need to change the gear oil and my mechanic didn't find the gear box oil tank to chick it up if it full or not
there is no bmw service point near me at the time
Old 08-21-2009, 01:25 PM
jay bimma's Avatar
i just hit 50k on my car this week. i changed the rear diff oil and it came out perfectly clean. it almost looked brand new. i just sucked it out with a mityvac fluid evactuator and then re-filled it.
Old 08-22-2009, 04:46 AM
Where did you find the oil tank give me a hint man ??!!
the mechanic tried to locate the oil mm without any benefit :thumbsdown:
there is no BMW service center near me and if i took the car to it . It will cost me a lot of money
Old 08-22-2009, 05:16 AM
pukka's Avatar
My Ride: 2008 535i: (8/07 Build) Metallic Bronze, Beige NASCA Leather, Ventilated Seats, Sport Pkg, Cold Wxr Pkg, Logic-7 Sound, HUD, Night Vision, PDC, Split Rear Seats, NAV, Premium Pkg, Comfort Access, HD Radio, Sport Auto Trans Current mods: M-Aero Kit, JB4, Motorcepts 6000k HID Foglamps Umnitza ICE-Lite 10w LED 6000k AE's 1992 Camaro RS: Fully Restored w/Custom Interior, 5.0L V8, T-tops, OEM Z28 Foglamps, Inst Cluster, & Spoiler, Custom Sound, Too many engine mods to list
If your mechanic can't figure out how to change the rear diff fluid without using a drain plug - then maybe you need to find another mechanic.
If there is no drain plug, just unbolt and brake the seal on the diff cover. Once its drained, re-seal (with new gasket) and add fresh gear oil. Shouldn't take no more than 30 mins.
Old 08-22-2009, 05:23 AM
Thank you very much man thats info is very helpful i will find another mechanic
Old 08-22-2009, 06:09 AM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Originally Posted by Dark Master 12' post='983942' date='Aug 20 2009, 06:26 PM
Hello there
If you're talking about the manual (or SMG) gearbox, this may help out:
https://5series.net/forums/index.php?s=&amp...st&p=941710
Old 08-22-2009, 06:15 AM
No it is an Automatic GearBox
Quick Reply: GearBox oil
