Gas Tank Door
My Ride: 2004 530i
Just happened today out of the blue, I went on my lunch break and when i unlocked the doors my gas tank door opened too. I couldn't get it to close, the only way to close it is to hold it closed then press the lock button my keys so that the pin comes out and holds it into place. But as soon as I click un-lock it pops open again. Anyone know what I am having this problem?
My Ride: 2007 E63 AMG | Obsidian Black | Schwarzes Nappa | Black BirdEye Maple | Premium II Package | Electronic Trunk Closer | Parktronic
Engine: RPi/Powerchips custom ECU tune, RPi Ram Air Kit (BMC filter, scoops), RennTech Sport exhaust, secondary cats, charcoal and resonator delete, custom AAA x-pipe
Exterior: 50% side windows / 35% rear window Formula One Pinnacle Series | Flat AMG hood emblem
Suspension: Renntech Lowering Module
Wheels/Tires: Radenergie R10, Falken FK452 245/30/20, Yokohama ADVAN Sport 285/25/20
2005 545i Sport SMG | Ti Grau | Schwarzes Dakota | Anthracite Maple | Logic 7 | Nav
Engine: Custom AFE CAI, Superchips ECU remap, Sprint Booster, RDSport Dual Exhaust Conversion with Quad Pipes and X-pipe, 3 resonators deleted, 90mm tips!
Exterior: M-Tech Aero kit | M5 Mirrors | M5 Rear Bumper | Trunk Lid Finisher | Vorsteiner decklid spoiler | 50% Formula One Pinnacle Tint
Suspension and Brakes: Bilstein PSS9 coilovers, JBT BBK: 16" cross-drilled rotors, 8 piston and 15" cross-drilled rotors, 4 piston
Wheels: VIP Modular VR 02 20x9F, 20x10R | Toyo T1R 245/30/20F, 285/25/20R
Lights: PIAA 4150K Xtreme White Plus fog lights, AIB v3
MOST IMPORTANT: Hardwired V1; =)
ED Date: 4/7/05, Re-delivery date: 5/21/05
Karma.
My Ride: 2004 530i
Originally Posted by vegastrashed' post='451540' date='Jul 24 2007, 01:10 PM
Karma. ![Laughing](https://5series.net/forums/images/smilies/imported/laughing.gif)
OK OK i take back the comment i said about you earlier!!
Browse the correct answer from here
My Ride: 2004 530i
Originally Posted by Ricracing' post='451545' date='Jul 24 2007, 01:41 PM
My Ride: 2004 525i, Titanium Silver, Gray Leather, Premium Package, Steptronic trans, xenon adaptive headlights, sat. prep, no navigation, bluetooth, ipod adapter
Originally Posted by ImSort0fABigDeal' post='451561' date='Jul 24 2007, 02:57 PM
I can't find that part that holds the gas tank door ( i was thinking that it was some kinda magnet or something)
Sounds like the spring in your hinge must have given out.
My Ride: 2004 530i
Originally Posted by MDT' post='451582' date='Jul 24 2007, 04:26 PM
I played with my gas door and it seems that there is a spring in the hinge section that snaps open or closed. It is the spring pressure that holds the door closed. Without unlatching the door by pushing it in to make it pop out about an inch, you can grab the edge and just open it. So, it appears nothing holds it in except the spring pressure. Of course, once you lock your doors, there is a pin that pops out to lock the door shut.
Sounds like the spring in your hinge must have given out.![Think](https://5series.net/forums/images/smilies/imported/think.gif)
Thanks, I will check that out!
My Ride: E90 M3
Model Year: 2011
My Ride: 2004 530i
Originally Posted by kscarrol' post='451600' date='Jul 24 2007, 06:07 PM
This doesn't sound quite right, unless they have changed since my 2004 car. There is a spring which pops the door open but there is a latch that catches it when pushed shut and release when pushed again. Sounds like that catch is not working properly, especially if it stays shut if you hold the door closed then lock the car. When you lock, a secondary catch holds the door shut, pushing it or not. Sure you can pull it a bit and it has some play but it should catch to close and your's is not doing that. Sounds like a trip to the dealer...
