gas mileage?
Old Jun 9, 2006 | 12:32 PM
snadir's Avatar
My Ride: 1) 2004 BMW 530IAlpine WhiteLuxury PackageNavigation 2) 2009 Range Rover Sport Supercharged
does having bigger rims and tires affect gas mileage at all?
like going from 17' runflats to 20' low profile tires..
if so, is there a big difference?
Old Jun 9, 2006 | 12:48 PM
nickolas_g's Avatar
Tires are the largest part of drag on a car. Aero dynamically and rolling resistance wise.
So yup, you will get less MPG.
Old Jun 9, 2006 | 01:29 PM
merklebob's Avatar
My Ride: 2005 545, nav, sport, PP, cold weather
nope. assuming you keep the same rolling diameter. the 20" may give you better mpg due to less rolling friction of the smaller side wall flex. but it not worth the price nor the lack of handling you'll get form to 20"
Old Jun 9, 2006 | 03:25 PM
Freewilly's Avatar
My Ride: 2013 535i (White with Oyster Interior. Premium Package, Navigation, Technology Pacakge, Park Distance Control, and Rear View Camera)
For aero dynamic, are you referring to F1 racing? I don't think regular car has much to do between tires and aero dynamic
Old Jun 9, 2006 | 09:46 PM
M-B lover's Avatar
In your example, more than likely yes, but probably not enough for you to notice. Things like a wider tire and a possibly smaller tire diameter can have a small effect. The biggest issue will be the weight of the new wheel/tire combo. Depending on the wheel, you could easily increase the weight by 15 lbs or more per wheel. That will affect your milage as well as slow your acceleration and increase your braking distance. The tire will play a role as well. A sticky performance tire will offer more rolling resistance than a super-hard economy one.
I think if you keep the wheel weight to a minimum you should be okay.
Old Jun 10, 2006 | 06:26 AM
DD694's Avatar
My Ride: 2006 550i Sport Package, Cold Weather Package, Premium Sound Package, Comfort Access, Xenon Headlights, Adaptive Headlight Control, Navigation System, Steptronic Transmission. Silver Gray Metallic with Gray Leather. Added Red rear reflectors. Swapped stock Style 124 wheels and Bridgestone run-flat tires for BMW Style 125 5-Double Spoke wheels, 8" x 19" front, 9.5" x 19" rear with Michelin Pilot Sport PS2 tires, 245/40YR-19 front and 275/30YR-19 rear.
Runflats are very heavy tires.
Old Jun 10, 2006 | 12:36 PM
jet190rs's Avatar
You have to also take into account weight of the wheels and tires. Lower weight = better gas mileage.
andymax
May 20, 2018 11:32 AM
PakiBeamer
Dec 9, 2016 04:40 AM
bestofthebest
Mar 28, 2016 02:47 PM
Jiawei Zhao
Oct 21, 2015 08:46 PM
bimmerspeed
Sep 3, 2015 09:29 PM
