Fuel Pump / Overfill Gas tank accident
a little help or suggestions. I accidentally overfilled my gas tank. Clicked off prematurely and thought it was not full. I WAS WRONG. Now have gas smell coming from right rear..
No fuel pump codes and was running MHD 25% E85 map.. No fuel pump upgrade. DCI CPE charge pipe Wagner FMIC Inlets Am i screwed of what?? Charcoal Canister? evap mess.?? No smell in the car just outside the car. Been about a week now, and ran the tank to under 1/8 and refilled with standard 91OCT. re-flashed to stage 1+ :oops: |
Originally Posted by Johnnyfive
(Post 1589991)
Originally Posted by FormerE30Owner
(Post 1590002)
Is the car running OK? Just wait it out - the charcoal canister is probably saturated with gasoline and will take time to evaporate through the air induction system. The charcoal is designed to absorb vapours, not "sponge" liquid./COLOR]
thanks for the reply. The only change that I really noticed is the cars idle is a little rough. I reset the Lambada and octane rating flashback is stage 1 it's been running smooth for the most part. When I adjusted the idle and mhd settings to 750 it did take the idle away a little. I am getting 2fca 2fda shadow codes. They say high pressure and then german.. all the research that I've done on these two codes have nothing to do with the fuel pump though really weird and low pressure fuel sensor is running in the 70% range which is normal I think man.. |
your fuel pump won't be affected. You overfilled and it flooded the charcoal canister. Will take a long time to dry up. May cause other emissions/evap errors, not sure. I'd just wait it out.
Originally Posted by LessIsMore
(Post 1590126)
Been getting High Pressure shadow codes but inactive. Going to clear through impa. Fuel pressure running 70's -80's and think that is normal. No signs of fuel pump failure thus far! |
