Fuel pump changed but still limp mode
535i 2008
I just got the car back from dealer today.. She said they changed the fuel pump .. here is what it says on invoice...Does anyone understand these codes faults?
Read faults : 5f77/29f2/2abc/29cc/29ce/29cf/2ca7/2cab/30ff
Work threw test plan for fuel pump/pressure will not acced 50 bar/Rem intake boots/fuel lines/t-body rep fuel pump/Progmann and encode v27 02 01/ set STR angle/test fuel pressure/low @ 5bar/hp @ 50 to 114bar
part number : 13-51-7-585-655 rmfd fuel pump... Can anyone explain this crazy stuff? Also im still getting limp mode today and when i put ignition on a exclamation mark still pops up and the check engine light stays on untill i start car completely..... ? please helpsomeone.. I cant be the only person with this problem... thanks for the help
spitfire23
05-12-2015 04:23 AM
