Fuel leak from small hose (engine bay driver side)
Old 01-06-2017, 06:04 AM
alfa_romeo55's Avatar
My Ride: BMW 545i 2005
2005 545i Update to fuel streaming out of my fuel line and hope that it lends knowledge to your problem to the Original poster.... I had fuel streaming out a pin hole on the bend of my black plastic coloured fuel line before it connects to the braided fuel line. Turns out my coupling/connector had all kind of dirt and crud in there making the contact not so secure. I cleaned the connector/Coupling with WD40, reattached the two lines together and no more fuel was streaming out the pin hole on the bend. Apparently its a black plastic film over the aluminum fuel line and pressurized gas gets in between the black plastic film and the aluminum fuel line and has to find a way out. An inch down the pipe, the pipe bends and there it would stream pressurized fuel....Thanks to H F who guided me on this simple operation. Turns out the coupling/connector was dirty......
Old 01-14-2017, 04:09 AM
clamar545i's Avatar
My Ride: Halo, Full exhaust, HId, interior light, AUX
I have the same problem I was going to do the cut repair��. This time around I saw the pressurized fuel misting out. Thank you for saying that about the plastic coating over the tube. I will try this today . How did you despressuresize the fuel line?
Old 01-14-2017, 08:13 PM
westsidebalto's Avatar
My Ride: Sold: 545i, sport package, cold weather, 6MT
Engine: N62
Let the car sit for a while, disconnect the battery (to reduce the chance of spark), open the gas cap (to relieve pressure), then place a rag or bag around the connection when you go to open it. I would also wear gloves and eye protection.
Old 05-04-2019, 01:32 AM
MAUI530's Avatar
My Ride: 2006 5 series 530xi sports wagon
Default Name of black tubing
Originally Posted by alfa_romeo55
Gentlemen,
I have a 2005 545i 6 speed....I have noticed a small stream of fuel coming from a hard black plastic tube on the drivers side connected to the braided fuel line which is connected to the fuel rail. What is the name of that black tube and where can I order it.
Much appreciated.
Alvin
alpha_romeo55 did you ever get the name of the black plastic tubing?
darnell moore
07-08-2023 09:38 PM
Royalty_Bimmers
12-20-2020 05:55 PM
Rizbel
03-05-2013 05:18 PM
bimmer_12
03-25-2010 04:02 PM
Mr.Bavarian
04-21-2009 08:33 AM
Quick Reply: Fuel leak from small hose (engine bay driver side)
