Front Tire on passenger's side noise...
So I recently changed the front brake pads and rotors. Now when I'm driving in a straight line it makes a squeak, squeak, squeak noise. The noise is coming from the front passenger's side and when I brake sometimes it will go away or the brakes will squeal a bit. The squeaking noise seems to fade when I turn to the left, but gets stronger as I turn right. Someone said it was the wheel bearings? But I doubt it because my 545i only has 32,000 miles and then I was told that it could be the CV axle shaft, but I looked that up and it makes a click click click noise, and not the squeaking that I'm getting. Anybody got any ideas???
My Ride: 2004 525i
I hope you find a solution to your problem. My girlfriend has a corolla and her dad changed the rear pads on it and now it squeaks too.
