Front LCI confussion
After fitting Halogen LCI lights to replace my existing pre-LCI halogen lights, all is well, and working fine.
However, I have noticed of a few LCI lights, that the angel eyes are really bright - a lot brighter than mine, which I presume is only on the latest models coming out to comply with the 'Daylight running Lights' which are to come into force in a couple of years.
My question is, what is different in my LCI lights to these, and can mine be changed to make the Angel eyes just as bright?
I know the differences to the Xenon and Halogen LCI's, and that there is not much in the way of after market bulbs for the halogen LCI's, but the new cars I have seen were Halogen lights, but with very bright Angel eyes......
Any idea's???
Cheers
Any idea's???
Cheers
Any idea's???
Cheers
Any idea's???
Cheers
Problem is, that unless you are quite close, it isn't that easy to tell if halogen or Xenon if only the angel eyes are on.
Regards,
Originally Posted by 525d MSport' post='860157' date='Apr 27 2009, 07:41 AM
Stuart, I have not seen a difference in brightness on LCI halogens. Will look out for it though.
Regards,
Regards,
Originally Posted by gblass' post='860977' date='Apr 27 2009, 08:45 PM
I take it you got the new modules for the LCI conversion?
The lights I am talking about are similar to the ones you now see on the latest 3 series too...
did you uses a relay for the angeleyes? Do you get any error messages?
The reason yours aren't as bright as Xenon LCI is because Xenons use a 35W H8 bulb and Halogen LCIs use a 10W BA9 bulb
bapeforceone
04-23-2015 06:30 AM
ianmosiah
04-22-2015 01:01 PM
