Front end stange behaviour
Old 05-19-2009, 02:08 PM
spiros's Avatar
I've just noticed this today and i was abit surprised. While stationary, if i turn the steering wheel from lock to lock , the nose of the car goes up and down depending the position of the wheels. We are talking about a good inch of movement that i can notice on the bonnet !
Does anybody have a clue why this is happening ie anything to do with active suspension ?
Old 05-19-2009, 02:12 PM
Krozi's Avatar
Probably just for better handling and stuff.
1979 posts and such an educated answer
Old 05-19-2009, 02:19 PM
spiros's Avatar
yes, i was just admiring the depth of knowledge and the use of niche technical terms used on the reply
Old 05-19-2009, 02:33 PM
Krozi's Avatar
I am sure someone else will chime in to give you a real answer
Old 05-19-2009, 04:22 PM
leventor's Avatar
My Ride: 2004 (7/04) 545i 6-Spd Manual Metallic Silver Gray with Gray Interior Premium Pkg, Premium Sound, Sport Pkg, Cold Weather, Active Steering, Navigation, Rear Sunshades, Folding Rear Seats, Rear Side Shades, Logic 7, Comfort Seats, Rear Heated Seats, HUD, Rear Side Airbags, PDC, Bluetooth Retrofit Exterior: Venture Clear Bra, Bright Angel Eyes, Euro Reflectors, Blackened Grill, VMR 713 19" Staggered with General UHPs, 13% tint rear windows Engine: K&N Air Filter, Deleted Carbon Filter , RPI Scoop, RPI Exhaust
This is to get better handling and responsiveness. As far as I know only Mercedes and BMW has this feature, and basically the front wheels do not turn only but also lean like a motorcycle towards to the direction you are turning the wheels.
Old 05-19-2009, 04:32 PM
Krozi's Avatar
See? Exactly what I said
Old 05-19-2009, 04:35 PM
Furious_g's Avatar
It's called caster. It produces a jacking effect which changes load on each contact patch. It also winds on more camber the more you turn the wheel, thus standing the front of the car up on the shoulder of the tyre.
You can ready about it here: http://en.wikipedia.org/wiki/Caster_angle
Even if your car does have active suspension, it would be dormant becuase the car is stationary.
All cars do this, the more caster, the more it does it.
Old 05-19-2009, 05:07 PM
mikeg3tsguap's Avatar
correct i believe dodge is doing this now in some of there higher end vehicles srt's for example i think
Old 05-20-2009, 06:06 AM
spiros's Avatar
Old 05-20-2009, 09:01 AM
flyingpuck's Avatar
TFF! It's time for Junior to get back to class!!
Quick Reply: Front end stange behaviour
