front crankshaft seal leak
Old May 29, 2015 | 06:24 AM
yelcab2's Avatar
My Ride: 2006 530xi touring
Engine: 3 liter
The front pulley is removed by taking off the 6 little bolts with the torx heads. Do not touch the big center nut. All is done with hand tools, no power tool needed.
Old May 30, 2015 | 06:22 AM
DavidF's Avatar
My Ride: 545i sport
Originally Posted by yelcab2
You don't need a crank holding tool to change the seal.
I admit that all the front seals I have replaced have been on V8's. For those the front hub has to come off. The hub bolt has over 300 ft-lbs of torque on it...thus you have to hold the crank. To remove the seal, I run a couple of small sheet metal screws into the metal part of the seal and use the screws to then pry the seal out.
Old May 30, 2015 | 12:43 PM
yelcab2's Avatar
Engine: 3 liter
Well, that is a different design.
The V8 seals, have a metal front face where a metal screw will hold and can be levered off. The N52/54 seal has a hardened rubber face, and there is not enough integrity to use a metal screw. You need a proper tool.
Old Jun 7, 2015 | 12:41 PM
stilldre54's Avatar
My Ride: bmw 530i
yelcab2 if you don't mind I would like to know where I could purchase that tool and how much it will cost me I might as well buy one because I might need it again in the future
Old Jun 7, 2015 | 06:36 PM
twh's Avatar
twh
My Ride: 2006 BMW 530xi 6MT
Engine: N52
Amazon.com : BMW Crankshaft Front Oil Seal Removal/Install Kit (N40/N42/N45/N46/N52/N53/N54 : Other Products : Everything Else Amazon.com : BMW Crankshaft Front Oil Seal Removal/Install Kit (N40/N42/N45/N46/N52/N53/N54 : Other Products : Everything Else
Not used this myself.
Old Jun 8, 2015 | 06:10 AM
yelcab2's Avatar
Engine: 3 liter
Then you do not know that this removal tool is worth less.
yelcab2's Avatar
Engine: 3 liter
I need to look at my paper work tonite. I will post it when I find it.
Old Jun 8, 2015 | 07:57 AM
twh's Avatar
twh
Engine: N52
Are you saying it is worthless? Or you don't know? I think I came across this having seen some youtube video of someone do a front main seal using this or similar design.
Old Jun 8, 2015 | 09:28 AM
pcy's Avatar
pcy
twh, what yelcab is saying is that he has used that tool and couple of other similar tools and they DON'T work. Supposedly these are original design. He is saying that he bought an improved version of that tool that actually works.
Old Jun 8, 2015 | 11:13 AM
twh's Avatar
twh
Engine: N52
Ok, got it. I'll wait for the post of the tool that works good. Need to file that away and hope I don't need to ever buy one
