Frigging Winter Rims, TPS, Tape....
My Ride: 2011 M3 Convertible, Alpine White/black, 6 speed
2011 535xi Tasmin Green, Venetian Beige
Okay, so I had my Winter set-up put on today. 18" Style 135 with Dunlop Winter M3 tires, same as with my last 550i. I spent $170 on TPS sensors, $40 on metal valve stems plus $160 to have the tires removed, TPS sensors installed, tires remounted and balanced and put back on the car. I'm happy. Sort of. I looked behind the spokes and can clearly see the white reside left by the old wheel weights and it pisses me off. I don't want to use Goo Gone to remove it because I'm afraid it will screw up the finish and scraping them might make it look worse. Any suggestions and/or sympathy would be most appreciated.
Thanks,
Jeff
Thanks,
Jeff
Saturate with WD-40, let sit 30-40 minutes, use your fingernails. If it starts to look dry, stop and repeat process. Then clean up with a little soapy water and hit with Wheel Wax or whatever you use. It will not harm the finish.
As already advised, clean up and wax afterward and you should be ready to leave that horrible weight tape stuff behind!
My Ride: 2008 Sapphire Black on Black M5 - loaded sans soft close doors
Drive around a little - that white residue will turn the same color as the rest of the rim (I believe it is called BDC - brake dust color). Deal with it in the spring when you take them off and clean them.
Originally Posted by CWS530' post='737432' date='Dec 3 2008, 09:49 PM
Check his sig--Axxis brake pads. Won't work.
since they gave you advice.. ill give you sympathy--- "ooooo that sucks.. dont worry itll be alright"
What happened to your '06 winter setting, JeffNNJ?
I still don't know what the TPS sensor are, my iDrive takes care of that.
Do you get the PSI readings on the iDrive? If so send in some pics, please!
Also pics of the white reside left by the old wheel weights would be nice.
Btw, they are easily removed - only some old glue.
My LCI has the normal BMW ABS sensor system.
No extra tires parts nor nothing is needed for that.
I payed 30 bucks for changing and storing (and washing) my summer wheels.
Did enjoy a nice meal as it was done.
TPS = This Part Sucks
Vman33
03-14-2022 04:43 AM
bestofthebest
03-28-2016 02:47 PM
